HELP!! alternator/motor
ok so i got a 89 mustang gt 5.0 and me n my dad put in a 130 amp alternator and now its killing the battery real quick like a day or so its different everytime some days it'll go 3 days without dying...the amp light is on so were guessing it may have to do with the alternator or battery...when we charge it up its runs perfect its a good running car when it'll run, we dont have any problems while driving it just after we park it then the problems come...if u can help me please reply back im only 17 years old lol and love mustangs so im trynna learn while still young...thank you and i hope somebody can help me...
If the battery/amp light is on, you know there's an issue. Has the alternator been bench tested? You can also have a dynamic test done at most parts stores for free (where they come out and check voltages for you, though I think you'll find you are simply running off the battery).
If you have a meter and want to test things yourself, check battery voltage with the car off. A fully charged battery has 12.6 volts. Start the car and recheck battery voltage. It should be over 14.0 volts.
You can also test the regulator wiring. The regulator is labeled A, S, I. A should show battery voltage. I sees accessory power (this is what tells the alt to turn-on. It also is the circuit for your battery light). S is the stator and should be looped to the solo spade terminal on the side of the alt.
Good luck.
