Help-amp voltage problem
  • Thread starter Thread starter lib88stang
  • Start date Start date Oct 12, 2007
lib88stang
154
Pa
Oct 12, 2007
  • Oct 12, 2007
Ok I have a 88 5.0 5speed car, here is the problem, The volt gauge (stock and autometer) usually reads 13.5- 14 volts thats at idle (around 1grand) and driving. But after driving for awhile the car when just idling seems to idle down to 700 rpms and volt gauge drops to 12 volts. Now it doesn't always do this. When it does drop the car sounds terrible. It just seems like somthing puts a load on the car and it drops. It has a new battery and alt, actually it has been doing this fora couple years not so its had a few batterys and alts. The battery is still up front and both terminals are new. It doesn;'t idle surge it just drops a little and sonds bad. Any help is appreciated. thanks
HISSIN50
34
129
Oct 13, 2007
  • Oct 13, 2007
How is the cold idle and loaded idle?
You could have an issue with your IAC, a bad sensor (ECT, et cetera), some sort of vac leak issue or something along those lines.
If you haven't, start with pulling codes. If you get lucky, the puter will give you a clue as to what's up.
Good luck.
lib88stang
154
Pa
Oct 13, 2007
  • Oct 13, 2007
Cold idle is good and loaded is usually good also, this just happens every now and then. I did change the IAC and I have cleaned the mass air meter. It is a 88 car but I cahnged the engine harnes to a 88 Cali cars for the mass air swap. Thats been a couple years ago, It has no pollution or AC stuff on it and stil runs strong just that idleing down and sounding bad is driving me crazy.
lib88stang
154
Pa
Oct 14, 2007
  • Oct 14, 2007
Set timing today, it was at 10deg and I bumped it to 14 seems to run stronger and wasn't idling down but we will see.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
