  • 1994 - 1995 Specific Tech
Help ASAP with Long tubes!!!!!!!
  • Thread starter Thread starter Guero
  • Start date Start date Nov 17, 2006
1 of 2 Next Last
Guero
2,148
Nov 17, 2006
  • Nov 17, 2006
I cant put them in!!!!!!!! Is there like a trick or magic word i have to say , seriously though.... i tried from the top, the bottome with no luck!!!!!!!!!!!
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 17, 2006
  • Nov 17, 2006
Did you do a search for LT installs on here yet? I would look there.
Oh, you did lift the engine while trying this, right?
Guero
2,148
Nov 17, 2006
  • Nov 17, 2006
damn i do??? Well i got the driver side in with out any problems. **** i need to be done by saturday morning. There gonna tune it. And yes i just searched found a link by you...Thanks. Man this sucks i gotta unbolt the mounts!!!!!!! Man and im gonna have to do this again when i install the t-56!!!!!!!!1 Damn it!!!!! Im off to bed!!!!!!!
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Nov 17, 2006
  • Nov 17, 2006
Haha, I'll post it here, too ..... so you can use it for quick reference if needed.
http://www.allfordmustangs.com//Detailed/2024.shtml
BTW, that is for a Fox, but there should be little to no difference.
Black Stampede
1,811
Grand Rapids, MI
Nov 17, 2006
  • Nov 17, 2006
Yeah, motor needs to come up a decent amount. The driver side is the harder side so you should be in the clear. Starter has to come out so keep that in mind, otherwise the passenger side is cake.
94gts
873
Carmel, New York
Nov 17, 2006
  • Nov 17, 2006
sleep is for the weak
Stanger007
2,015
Baton Rouge, LA
Nov 17, 2006
  • Nov 17, 2006
I had to jack my car up HIGH and then also jack the engine up till it hit the firewall to make it clear on my passenger side.
Pain in the butt... but well worth it. When you are done you will be ->
Wes
Guero
2,148
Nov 17, 2006
  • Nov 17, 2006
Is the egr tube on a different side than the shortys???? I cant still make this work!!!! Im disconnecting the starter i didn't read that part
Guero
2,148
Nov 18, 2006
  • Nov 18, 2006
Man its a bitch do do long tubes. i should of stayed with shortys!!!!!! Are they even worth the power gain??? I got some 1 3/4 inch
WhiteDevil
2,717
San Diego
Nov 18, 2006
#10
  • Nov 18, 2006
  • #10
thats little big for a h/c/i combo
Guero
2,148
Nov 18, 2006
#11
  • Nov 18, 2006
  • #11
I got nitrous 2. i was like um 1 5/8 or 1 3/4??? Its only 1/8 of inch bigger, and an inch an together.
Pokageek
2,767
MA, USA
Nov 18, 2006
#12
  • Nov 18, 2006
  • #12
Sounds like a killer combo. Good luck with it. Mustangs have the absolute meanest sounding engines ever. That thing is going to rock.
Guero
2,148
Nov 19, 2006
#13
  • Nov 19, 2006
  • #13
Yeah they do have the best sounded engine!!!!!!!!
Guero
2,148
Nov 19, 2006
#14
  • Nov 19, 2006
  • #14
Man im still not done these ****ing bolts are a bitch!!!!! I had to gring down the bolts that go on the inside side of the tube header!!!! And they still go in sideways. I just need to more and im of to the welding shop!!!! But i cant grind them enough for it to work.... Should i get studs or waht the hell!!!!!!!!!!!!
Y
yellow1995Cobra
2,959
Massachusetts
Nov 19, 2006
#15
  • Nov 19, 2006
  • #15
get kooks next time (if u have the money) ., Being able to put them in one primary at a time is KEY
bigap15
115
#16
  • Nov 19, 2006
  • #16
one primary at a time is key, for the first install. But if u ever have to take them back off, prone to warping.
Therian
The Highlander
Waterloo, Ontario
Nov 19, 2006
#17
  • Nov 19, 2006
  • #17
I've heard a lot of this but have not seen it in person. I'm thinking a lot of people over torque the header bolts without knowing it.
Guero
2,148
Nov 20, 2006
#18
  • Nov 20, 2006
  • #18
Im finally done!!!!! Now i need to take it to the muffler shop for them to cut and connect everything again! LT are a pain in the ass!!!!!!
ProKiller
3,064
15
78
PA
Nov 21, 2006
#19
  • Nov 21, 2006
  • #19
shut up you'll be happy in the end
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Nov 21, 2006
#20
  • Nov 21, 2006
  • #20
+1, this guy whines too much
1 of 2 Next Last
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Axleback installation
  • Bob Foos
  • Jun 13, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
D
Help--Need New Exhaust Gas Recirculation (EGR) Tube for 1994 V6 3.8 L Mustang--where can I find one?
  • DPP
  • Jun 5, 2025
1994 - 1995 Specific Tech Jun 10, 2025
DPP
D
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
