help asap
Some one might have glued them together you could try soaking it in gas.
if that doesn't work put it in the microwave for a couple of minutes then when your at sears buying a new microwave you might see something that you can get it off with
bluidvl said:
ok tried hammer that wont work :shrug:
Get a bigger hammer...
Seriously, remove the studs by double nutting them and unscrew them from the upper manifold. Once the studs are out, a very large rubber mallet, like the ones used to beat hubcaps to death, is the instrument of choice.
