Help auto trans /tow dolly
  • Thread starter Thread starter koss1000
  • Start date Start date Aug 14, 2004
K
koss1000
22
N.Nevada
Aug 14, 2004
  • Aug 14, 2004
I bought a auto trans mustang today drove it seemed fine put it on the tow dollie in neutral and when i got it home no reverse.. then took it out in drive only had first gear.. WTF???? did i get scammed somehow? help help It was a 91 LX
timewarped1972
642
mesa, az
Aug 14, 2004
  • Aug 14, 2004
it may have already been ready to die, i know there's certain things your supposed to do when you tow automatics like disconecting the drive shaft because as it spins there's nothing to lubricate it inside the tranny but thats only if you tow it for a long distance i believe.
blk92stangg
583
Hawaii
Aug 14, 2004
  • Aug 14, 2004
Aye, how far did you tow the car from?
J
Js5ohLX
287
Ohio
Aug 14, 2004
  • Aug 14, 2004
When towing an automatic, you need to stay at 35 mph for 5 miles. Some automatics are not towable at all. You should have pulled the driveshaft, because you just cooked your trans. I don't believe you got scammed.
K
koss1000
22
N.Nevada
Aug 14, 2004
  • Aug 14, 2004
You guys are right its cooked GRRRR well looking into a rebuild. thats a grand in the ass
K
koss1000
22
N.Nevada
Aug 14, 2004
  • Aug 14, 2004
blk92stng reallyhow hard was it to do that conversion.. Much rather have a T5 in this.. its a totally clean car with a fresh 302 in it..
john
J
Js5ohLX
287
Ohio
Aug 14, 2004
  • Aug 14, 2004
The hardest part of the swap is putting the clutch pedals in. And that's not really too hard.
H
HighMileage
37
  • Aug 14, 2004
Wow, I had no idea.
A car eventually has to be towed, when it breaks down.
D
Daggar
3,902
  • Aug 14, 2004
HighMileage said:
Wow, I had no idea.
True, but usually they're flatbed towed. If not, then they're towed on the buddy bar from the rear of the car with the front wheels on the ground (if it's a rear wheel drive car).
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 15, 2004
#10
  • Aug 15, 2004
  • #10
ROLLBACK THAT BASTARD
H
HighMileage
37
#11
  • Aug 15, 2004
  • #11
Only as a solution to this particular automatic-towing problem ...
Could the car have been started, left in neutral (idling), and then towed in any way imaginable?
blk92stangg
583
Hawaii
Aug 15, 2004
#12
  • Aug 15, 2004
  • #12
Not sure highmileage.
As far as the T5 conversion, it just takes time if you are a home garage mechanic like me. I could only the car a foot or so off the ground, so you are on your back a lot. I also used air tools to zap the bellhousing bolts and other hard to reach, frozen bolts. All if all, if you can follow directions, have a friend handy to help you out, and a mechanically inclined mind, it NO problem. Check out westcoastfords.com for the how-to article I used. Everthing on the article was just as it was on my car, and I highly suggest you read it over a bunch of times. Good luck, and feel free to PM me if you need additional info, as well as do a search as there is a bunch of good info here to.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Yesterday at 6:09 PM
JD1964
