Ok well im doing my brakes and I tried bench bleeding my MC. I ran some hose off the two outlets into the top of the MC and filled it with fluid, then pushed the plunger untill most of the air came out then topped it up again, but then of course it keeps sucking air back in thru the top I could sit there for hours and it would keep putting little air bubbles sucking back and forth thru the line. So hows this help? Does it just get that air out at the start or what?
Some-one help me out here please!
ps: Also anyone have tips for getting the metal brake lines to connect nicely back into the MC, I had it on there and I stripped the damn MC because it was leaking since it didnt go in dead even since I had re-bend the metal lines and its hard to get them to line up excatly perfect, so I gotta get it re tapped/threaded and re-bench bleed it.
Thanks
Thanks
