help can't get traction
  • Thread starter Thread starter dkhead1998
  • Start date Start date Jan 30, 2009
D
dkhead1998
14
egg harbor twp,nj
Jan 30, 2009
  • Jan 30, 2009
i have a 90 lx and there is nothing special about the engine except for a crane powermax 2020 cam, but i cant get traction off the line can anyone help on the bestway to get traction?
88mouse
630
Mooresville nc
Jan 30, 2009
  • Jan 30, 2009
Need more info about the car. If its a manual transmission don't dump the clutch at 5000rpm try it about 2000.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 30, 2009
  • Jan 30, 2009
Do the driver mod (AKA practice). Most street tires don't make for good traction, and those that do, don't make for practical usage. On anything less than a drag radial and if you have a manual trans, you never want to dump the clutch and pray for the best. You need to ride it out on the edge of breaking traction.
D
dkhead1998
14
egg harbor twp,nj
Jan 30, 2009
  • Jan 30, 2009
it is a manual car andi dont dump the clutch just a little harder then normal i have BFG traction ta tires what is the best suspension setup i can use without going crazy
BlownFiveLiter
18
108
Chicagoland
Jan 30, 2009
  • Jan 30, 2009
You should still be able to find traction with bone stock suspension at your current mod level. If you're looking to do a budget suspension, some 4 cylinder springs and pretty much any quality aftermarket lower control arms should be good.
88mouse
630
Mooresville nc
Jan 31, 2009
  • Jan 31, 2009
The bfg traction ta is just a regular street tire.
strtrcr50
Previously from Dirty Jerzey exit 7a
Jan 31, 2009
  • Jan 31, 2009
Nice screen name. Try some nitto 555r drag radials. You'll hook then. What gears do you have in the rear btw?
7upstang91
936
124
74
Florida
Jan 31, 2009
  • Jan 31, 2009
I have those on my GTO they are pretty good tire but depends on the power level. I have steeda springs and upper and lower control arm will help alot. But the m/t drag radials E/T that I have hook really well on one of my stangs spin its only 235 tire with 388rwhp. Then i have 275 555 nittos NOT the drag radials that like crazy. Both mustangs have 3.73s. Practice is the best way to improve.
RYC CUKR
1,437
Orlando
Jan 31, 2009
  • Jan 31, 2009
What is the condition of the bushings in the control arms and what kind of shape are the torque boxes in? I would check to make sure that you don't have any bushings that are torn up and that the torque boxes are in good shape. The drivers side box in my 88 shot and I have a difficult time getting traction sometimes. If everything is in good shape the I would start with suspension work and tires.
I run a set of MM adjustable LCAs and MT drag radials on my 93. Works pretty good.
L
lang williams
567
cleveland, oh
Jan 31, 2009
#10
  • Jan 31, 2009
  • #10
I have that 2020 cam an its a low end torque cam. if you want to get radical you could retard the cam 4 degrees.
M
Makdaddymac
323
orlando
Jan 31, 2009
#11
  • Jan 31, 2009
  • #11
is there any way to know you are buying 4cycl springs instead of v8's? i think im going to do the 4cyc and LC-arm, and subframes for my suspension upgrade
7upstang91
936
124
74
Florida
Feb 1, 2009
#12
  • Feb 1, 2009
  • #12
Don't get 4cyl springs they are retarded. They don't work and are scary to drive in the slightest rain.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Feb 2, 2009
#13
  • Feb 2, 2009
  • #13
4-bangers seem to do fine with them in the rain.
Why would a spring make a difference on how the car handles in the rain?
V
v8only
2,378
22
49
Feb 2, 2009
#14
  • Feb 2, 2009
  • #14
they're not scary to drive. My friend did it for years. It's not unsafe either. It just sucks. you lose all your handling capabilities for staight line performance.
You need to check the obvious. Your trak lok.
I recently went to the track expecting solid 13's on my explorer combo.
I went with mt et streets, 26x10.5x 15.
best time I could muster was a 2.5 60' lol
spun all the way through first on the et streets.
Jack up just one side of the rear. leave one wheel on the ground, one in the air.
grab a torque wrench and put it on the rear lug. It should hold something like 25-28 pounds or so before the rear wheel begins to spin. If it doesn't, your trak lok is busted.
I tried this, and my trak lok is so bad that I can free spin the wheel with my hand.
Hence my traction problem.
As well, in my experience control arms do NOTHING for traction. Traction is a difficult problem with our cars. Good tires, a good trak lok and weight transfer are the best ways to get traction.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Feb 2, 2009
#15
  • Feb 2, 2009
  • #15
Not necessarily. I've been in the market for new arms and have been doing a lot of research lately and you can actually "ruin" traction with control arms that have poly bushings. The major player is the upper arms. MM actually recommends to keep the stock uppers with the rubber bushings to absorb some of the twist of the rear axle when you hit the power hard. With stiff bushings, there is no cushion and you tend to break the tires loose.
V
v8only
2,378
22
49
Feb 2, 2009
#16
  • Feb 2, 2009
  • #16
That is a good point. I wasn't thinking of it from that direction.
I actually went that route...kept stock type control arms for my uppers (cobra arms) then went with pro3i units for my lower..mm type arms with a spherical/poly combo.
On the streets I'll spin halfway through second still.
I didn't post my times, but I got a 9.6 in the eigth (equal to about a 15.0 in the 1/4), lol because of traction. I have a 13 second car too.
It's just crazy what an utter lack of traction will do to an otherwise quick car
I_AM_CANADIAN
189
B.C.
Feb 2, 2009
#17
  • Feb 2, 2009
  • #17
I believe that Ford considered anything under 30 lbs a failed trac lock.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
martroy
M
