HELP! car is sick! :[
  • Thread starter Thread starter Saphirestang89
  • Start date Start date Aug 24, 2008
Saphirestang89
18
Mt. Juliet TN
Aug 24, 2008
  • Aug 24, 2008
ok so here is my setup:
306 shortblock
gtp heads: 1.94" intake 1.54" exhaust springs good to .550 lift
e303 cam
gt-40 upper and lower
70mm t-body/egr spacer
in fender cold air
full exhaust
stock timing
problem: car seems to be running really rich, when it revs to 4k rpm or so
it bogs out..not like its got detonation it feels almost like hitting a rev limiter.
will not go past 4k rpm
everything on the car has been replace except the MAF and Distributor, and i think
thats about it. Im wondering if the maf may be messing up causing the car to
run to rich and basically flood the cylinders at higher rpm??? any ideas? im open to any and all suggestions
talladam
50
Monroeville OH
Aug 24, 2008
  • Aug 24, 2008
Any check engine light appearing? Personally I'd bump timing to at least 14 deg advanced for starters, higher if it doesn't ping. Gently clean the two maf elements with electronics cleaner and then clock the MAF. New ACT/IAT/o2's wouldn't hurt either.
Saphirestang89
18
Mt. Juliet TN
Aug 24, 2008
  • Aug 24, 2008
no check engine light
thats why im all like wtf
wildstang90
87
Bristol, TN
Aug 24, 2008
  • Aug 24, 2008
My 93 did that once ended up beeing a dirty MAF. Would run great with it would run fine with it unpluged. I would just try to clean it and yea mine never triped the check engine light.
HISSIN50
34
129
Aug 24, 2008
  • Aug 24, 2008
A bad coil or plat spark plugs can also cause a 4K RPM cut-out. When TFI's are in the early stages of failing, they often allow a 4K cut-out as well.
Good luck.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 24, 2008
  • Aug 24, 2008
i'm with hissin, i had problems (felt like rev limiter at 3-4K) turned out to be a bad coil. i have also had problems with distributors causing funny issues.
i would start out trying a new coil and TFI module and see how it does. if no luck or still has a problem, try a different/new dizzy.
Saphirestang89
18
Mt. Juliet TN
Aug 25, 2008
  • Aug 25, 2008
problem solved. Dirty MAF
cleaned it and its run perfect ever since
thanks for the help
:SNSign:
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
