  • 1994 - 1995 Specific Tech
Help Car Running Like #$**@)(#$*!!!
  • Thread starter Thread starter grrrrrrr
  • Start date Start date Mar 31, 2005
G
grrrrrrr
289
norfolk, VA
Mar 31, 2005
  • Mar 31, 2005
My car hesitates and backfires on medium throttle between approx. 1500 and 3000 rpms and pops when idling down the road with no throttle applied (rpm's up, no gas) At full throttle the problem isn't so pronounced, and there is no backfire or hesitation above 3000 rpms. During full throttle exceleration (I can't spell) the car drives okay, with no problems above 3000 rpm's, but when power shifting into second I noticed a louder than usual exhaust note as the clutch grabbed... Also, at very low throttle the car runs and drives fine. I pulled the codes and got these
KOEO (Key on Engine Off)
Stored:
327 = EGR Circuit below minimum voltage
332 = Insufficient EGR valve opening detected
543 + Fuel pump circuit open; Battery to PCM (what does this mean?)
KOER (Key on Engine Running)
313 = AIR not bypassed during KOER
314 = AIR system inoperative during KOER (Bank number 2 with dual heated oxygen sensors)
311 = AIR system inoperative during KOER (Bank number 1 with dual heated oxygen sensors)
What is this AIR system? and how do I fix it? I just replaced the o2 sensors about 3 months ago and I disconected the EGR on the way home today to see if that affected the problem (it didn't) so I'm pretty sure thats where the 327 code came from. The rest, I'm clueless on... Can someone help please?
None of these faults are consistent with the Hayne's manual diagnosis of the problem. I also had a fuel problem earlier. The retainer nut on the AFPR (kirban) came loose and I think the adjustment screw vibrated out a bit. I checked the fuel pressure before I screwed it down and it was sitting at 50psi with vacuum. I adjusted it down to 43 psi with vacuum (what the car ran best with on the dyno) and was hoping this would cure the problem. If anything, it made it worse... I also 5 days ago cleaned my air filter (K&N) and cleaned my MAF. I hope I didn't screw up the MAF but the car ran fine after I did this maintenance. Sorry for the lengthy post... but I need help...
94TURBO5 O
2,509
VA
Mar 31, 2005
  • Mar 31, 2005
It helps most to work backwards to where the car was fine before. Something my wife taught me b/c lots of time I'll work on a specific part and then do something else and the car will run freaky. Try disconnecting the MAF and the battery (-) and inspect it again as well as the FPR to make sure it's not messed up. If parts are not installed properly then of course they will fail to operate correctly in the whole scheme of things. Make sure that you IAT is facing in the correct direction when your screw it in.
G
grrrrrrr
289
norfolk, VA
Mar 31, 2005
  • Mar 31, 2005
Alright thanks... I'll check all of that...
94TURBO5 O
2,509
VA
Mar 31, 2005
  • Mar 31, 2005
Also try setting the fp to 40#s with the vac line OFFf and connect it back after the ajustment.
G
grrrrrrr
289
norfolk, VA
Mar 31, 2005
  • Mar 31, 2005
Okay, no change in status after trying these things, can anybody tell me what this AIR stuff is as pertains to codes 311, 313 and 314 in my original post. What is it supposed to be bypassing?
dstanggt50
1,316
Woodinville, WA
Mar 31, 2005
  • Mar 31, 2005
I'm not 100% sure, but I think all of the 3xx codes are smog pump related, I'm not sure if that would cause your issue, I'm pretty sure a lot of people get those codes when they remove their smog pumps, I had the 327 egr code on mine, didn't really have driveability issues, but replaced the egr and evp and the code and check engine light went away.
G
grrrrrrr
289
norfolk, VA
Mar 31, 2005
  • Mar 31, 2005
Bump...
G
grrrrrrr
289
norfolk, VA
Apr 1, 2005
  • Apr 1, 2005
Bump again...
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
