Help car wont start when hot
stang120gt
72
Michigan
Ok well my dad has a 90 gt vert auto. That just about every time it gets hot and you shut the car off it wont start. What it does when it's hot and you try to start it just cranks and cranks. We changed a hole crap load of stuff. Then we unpluged the fuel relay. After it cranked a couple of times it started and it's like it floods it's self somehow. We bougth a new relay and it still does it. We are so pissed off. It's been doing it ever since we put headers offroad/h-pipe and flows on it about 2 month's ago. We really need help guys.
But when it cools down it starts right up any idea's. :shrug:
Here's a list of things weved changed.
distributor module
dis. cap
dis. rotor
different distributor
fuel relay
fuel presure regulator
coil
I think that's it. But there might be some more things that we bought. ill have to ask my dad when he gets home .
Thanks guys
im going to go with a few things here, number one how old are the o2 sensors, assuiming u changed the headers over did u replace the o2's too. also it says you swapped the fuel regulator by chance can the regulator be leaking and flooding the engine, or even a bad leaky injector or fuel pump and filter.
lastly i say the starter is getting too hot especially with new headers and maybe is getting burnt out try a new starter.
Well they are not new but they are the one's that were in the stock h-pipe and they worked fine when they were in there.
The regulator is not leaking from what we see. (By leaking you mean gas all over the intake right) But there is no gas leaking. We can smell gas when it wont start but thats it. I dont think it's leaking and for a leaking injector there is no gas coming out from anywhere. :shrug:
We thought fuel pump but why would the car not start when it hot.
The starter is not having any problems it crank's when it's hot and cold but when it's hot it wont start :shrug:
Try the coil.....I had a similar problem in hot weather last year and i couldnt figure it out. By chance i had a extra coil in my trunk (the original) and i swapped it in. Its been fine ever since. I learned that over time the coils get cracked and after it heats up the cracks expand which causes the spark to be to weak.
Good luck,
Pat
thats one thing i for got to list but we already replaced it
Good luck,
Pat
think you my have a fualty fuel pump bad internal check valve where when the car shuts off the fuel pump leaks letting air back into the system and causes a vapor lock. the fuel lines need to be filled with fuel first to build up enough pressure to start the fuel injectors to inject
you think that would happen when the car is hot only. I would think that if thats the prob then it would do it all the time right :shrug:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Ehhh,
Both of my 91's had the same problem
New Starter fixed both.
(on one I replaced tons of stuff, neg wire, selonoid, starter, roter, dist cap, and the module, while all of these things helped, in the end it was the starter for the heatsoak and the module for cut out and Fuel pump after that for cutting out, ouch I am just thinking about all the stuff I had replaced in that car... LOL)
I see you have not replaced it yet.. Just an idea.
