help....check engine light is coming on
90copcar
when the engine is under load, at about 3500 rpm the check engine light comes on, then goes off when the rpms come back down. i adjusted the tps switch and it was off a little, but it still does it. if you rev it up in neutral, the light doesn't come on....it also isn't related to speed, just under load...help :(
