  • 1994 - 1995 Specific Tech
HELP, Cracked block?
  • Thread starter Thread starter mackey
  • Start date Start date Dec 8, 2005
M
mackey
1,284
Beverly, Massachusetts
Dec 8, 2005
  • Dec 8, 2005
Well I had some antifreeze in my car, but now it froze because I didn't have enough. Seems like the car won't crank... There is no leakage anywhere under the block. The car almost kicks but nothing... Where do I start I need to somehow flush the coolant system.
bjl95mustang
1,495
Austin,TX
Dec 8, 2005
  • Dec 8, 2005
Sounds like a low batt.
94MustangGT5.0
288
Champaign, Illinois
Dec 8, 2005
  • Dec 8, 2005
Yeah, I wouldn't jump to any conclusions about a cracked block just yet. That's why they invented freeze plugs, check you battery.
M
mackey
1,284
Dec 8, 2005
  • Dec 8, 2005
It seems to be losing coolant by the front of the block where the head meets the block... Hoping for a headgasket...
YEAHLOH95
1,249
EVERETT,PA
Dec 8, 2005
  • Dec 8, 2005
water pump?
M
mackey
1,284
Dec 8, 2005
  • Dec 8, 2005
I believe the thermostat got hydrolocked and the water was boiling over in the engine. It was not allowed to get out because there was too much steam/water in the radiator so it boiled over blowing the headgasket. I guess I'll find out for sure tomorrow.
I thought I had antifreeze/water mixed but it ended up nt enough antifreeze... I'll keep this post updated with pictures.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 8, 2005
  • Dec 8, 2005
Its just an excuse to build a n/a 347
M
mackey
1,284
Dec 8, 2005
  • Dec 8, 2005
Well I do have that 357w in my shed.
:evil:
Now if i could only find some cheap 351w swap headers and an intake.
Does anyone know if the TFS R and TFS street share the same lower for the 351 and 302?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 8, 2005
  • Dec 8, 2005
The R and street lowers are different. Trickflow only makes an R manifold for 351 based engines. You can not use a 302 lower on a 351, the 351 block is wider but i'm sure you know that.
M
mackey
1,284
Dec 8, 2005
#10
  • Dec 8, 2005
  • #10
Yea i know. I was just hoping the ports would be the same because they look relatively similar. I figured there would be a difference. Oh well. I'll just do headgaksets if thats all thats wrong and be cheap about it till i can afford to go up in cubes. College > me. Co-Ops start soon and i'll be hopefully making more money than I am now.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 9, 2005
#11
  • Dec 9, 2005
  • #11
The R ports are a bit bigger. I put my street heat gasket up to my R intake and the street heat gasket really interrupted flow! The bolt pattern is the same I think so it will bolt on to it.
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
