  • 1994 - 1995 Specific Tech
Help-- Ebrake handle problem
  • Thread starter Thread starter topless95
  • Start date Start date Mar 8, 2008
T
topless95
27
North Florida
Mar 8, 2008
  • Mar 8, 2008
My e-brake cable broke, and when it did the spring on the e-brake handle came unwound. Does anyone know of a site that has explicit instuctions/pics on how to set the spring properly?? Or does anyone have pics and able to give detail instructions from personal experience?? Thanks in advance
T
topless95
27
North Florida
Mar 8, 2008
  • Mar 8, 2008
anyone???
earleys94gt
1,223
Ashley, Ohio
Mar 9, 2008
  • Mar 9, 2008
This might help http://www.allfordmustangs.com/forums/5-0l-tech/9044-e-brake-problems.html
Another http://www.allfordmustangs.com/forums/94-95-tech/82523-how-do-you-fix-emergency.html
Hopefully this points you in the right direction, good luck.
desertcox05
379
south atlanta
Mar 10, 2008
  • Mar 10, 2008
mine broke about 6 mos ago. it wasn't too hard to do. you don;t have to pull the whole consol out, only the bottom of the arm rest and you may have to drop the drive shaft depending or you clearence it only took me a couple of times rewinding the spring before i finially got it right
you can do it good luck
Methodical
1,192
11
59
Clinton, MD
Mar 10, 2008
  • Mar 10, 2008
FYI: Go to the dealer and get the Ebrake cable. Don't order from Summit and other places like that because they are not the correct cable for our cars. So save yourself some trouble if you have not gotten the cable yet.
Also, I have step by step instructions at home. I will post when I get home. But a small tip now though is you will need a nail (I used a finish nail) to slip into the hole on the side of the spring to keep it in place once you rewind it. The nail or whatever you use needs to be small enough so you can slip the console back on and be able to pull it out.
Again, if you have not started and can wait 'til tonight I will post the step by step instructions. Let me know.
T
topless95
27
North Florida
Mar 11, 2008
  • Mar 11, 2008
Methodical, that would be great!!!
  • dan50
  • Jul 18, 2026
dan50
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
  • mnky99
  • Sep 5, 2025
mnky99
M
