HELP FAST...Brake Light Switch...
When I was doing some work in that area b4 I had a switch quit working.
Thats one of the most used parts in your car.
They tend to quit working sometimes. exp if you have been messing with it.
Maybe take it lose but leave it wired up and try to make the lights come on by using your hand to activate the switch.
If that doesn't work it's the switch.
there fairly cheap most parts houses stock them.
It should just slide right on the brake pedal and is held on w/ a cotter pin. The two progs that come out of it should be facing the rear of the car. Is the switch making contact w/ anything to activate it w/ the pedal is pressed? It should....
