so if i get the 5 lug conversion from latemodel, and i get sn95 spindles, is that all i need to make bullits work? stock size tires. where can i find spindles and what else will i have to do?
You can get a ball joint press that looks like a big c clamp from harbor freight for $20 or so if you want to do your own ball joints. I used it an it works really well, you can change the ball joints right on the car. But the spacer set up is the cheapest route.
www.ebay.com
I got complete 1995 spindles with rotors, calipers and brake lines off ebay
for little over $200.
Then get the SN95 ball joint swap kit from 50resto.com and have machine shop
swap them out on your control arms for you.
Excellent write up
http://www.stangnet.com/tech/lug.html
