help guys >_< sound
Nov 21, 2011
71
This just started today on my way home the car View attachment 138845 is making a put put sound and i feel power loss... in neutral i hear a ticking sound coming from under the car i pulled the codes and there was nothing new did a tune up changed the oil 2 months ago got a new clutch installed about a month ago...
this really sux because its raining and im a month away from getting a bike
Check that the header bolts are tight. Check where they connect to the heads and check where they connect to the mid pipe. I used to have the last 2 bolts near the firewall on the drivers side that liked loosening themselves. If you find its the bolt that goes into the head try using some loctite on the bolt threads.
