  • SN95 4.6L Mustang Tech
Help! Hard starting problem
  • Thread starter Thread starter 2013 Geee T
  • Start date Start date Mar 30, 2007
2013 Geee T
805
Oak Park, CA
Mar 30, 2007
  • Mar 30, 2007
I’ve been having an on going problem with my car turning over and not starting. It’s completely random and would turn over a few times and then finally start. This morning it would not start for a very long time. I kept trying and trying and finally it started. I replaced my IAC valve last weekend hoping that would make a difference and it didn’t.
My friend who has been a mechanic for years and works for Honda and he said they have anti theft receivers in the ignition where if you use the wrong key it senses it and cuts the fuel and will just turn over and not start. He said sometimes the receiver/sensor goes bad. Do Mustangs have a similar thing and could that be it? How would you test it?
Any other things I could check? I dont want to get stuck 25 miles away from home at work!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 30, 2007
  • Mar 30, 2007
Does it only do it when the engine is fully warmed up?
2013 Geee T
805
Oak Park, CA
Mar 30, 2007
  • Mar 30, 2007
I seemed in the past that it did it when it was warmed up mostly but it was totally cold this morning.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 30, 2007
  • Mar 30, 2007
Clean the MAF and reset the PCM. It may or may not work but it IS free
2013 Geee T
805
Oak Park, CA
Mar 30, 2007
  • Mar 30, 2007
As in disconnect the battery?
I was planning on cleaning the MAF wire since Ive been getting some pinging
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 30, 2007
  • Mar 30, 2007
Yes, disconnect the battery. If the guages sweep when you start it up you were successful in resetting the PCM.
2013 Geee T
805
Oak Park, CA
Mar 30, 2007
  • Mar 30, 2007
Is it possible its the battery? I read a post where replacing the battery fixed it. Its the orignal battery. I guess I can have it tested.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 30, 2007
  • Mar 30, 2007
AutoZone will test it for free.
2013 Geee T
805
Oak Park, CA
Mar 30, 2007
  • Mar 30, 2007
Is it ok to clean the MAF wire with something like rubbing alcohol or do I need to get the electrical parts cleaner?
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
