Help I see smoke!
  • Thread starter Thread starter MoneygrubbinCar
  • Start date Start date Aug 23, 2007
M
MoneygrubbinCar
155
Jacksonville
Aug 23, 2007
  • Aug 23, 2007
I was coming home from work today and I noticed an ever so slight smoke coming from my steering column. It just started happening today I guess but it seems to do it when I run my a/c wide open. If I turn it down one notch it doesn't seem to do it. However I know I need a new steering rack and pinion assembly also along with inner and outer tie rod ends and being smoke is just coming from the steer I wondered if that had something to do with it? Like maybe powersteering fluid being burnt and it just so happens to leak through when I put the a/c on high. I'm really at a loss on what it could be I was gonna take off the plastic components around the steering column here shortly to check for burning. My a/c still feels as cold as it usually does if thats any help on figuring it out. As for the smell of the smoke its got a leather smell or mild burning rubber? I guess I really dunno its very faint and smoke is coming out like a smoldering fire from the night before I guess you could say its very small and hard to see. Thanks in advance!
fastford91
254
Niagara ,Ontario, Canada
Aug 23, 2007
  • Aug 23, 2007
this smoke is coming for inside the car? if so its probably a wire burning for ignition or air bag? that's where i would check first if its inside the car!
bullitstang1313
713
Indianapolis / Columbus, Indiana
Aug 23, 2007
  • Aug 23, 2007
If you have smoke coming from your steering column you should definately stop driving it to find out where it is coming from. A bad power steer rack has nothing to do with smoke coming from the steering column. Best bet is that you have an electrical short somewhere causing the wiring to get nice and hot causing it to melt.
M
MoneygrubbinCar
155
Jacksonville
Aug 23, 2007
  • Aug 23, 2007
Ya the smoke is coming from inside the car. I took the covers off around the column and looked for burn marks and didn't see anything. Its a grant steering wheel I guess thats what its called so I don't have an airbag nor a horn.
bullitstang1313
713
Aug 23, 2007
  • Aug 23, 2007
It could have to do with your ignition switch. Are you noticing any other electrical issues? There is another post going about turn signals and AC not working that mentions information about the ignition switch. Check it out here There used to be a recall on the ignition switch.
M
MoneygrubbinCar
155
Jacksonville
Aug 23, 2007
  • Aug 23, 2007
Ya I looked at the other thread. I went back out and played a little more the only thing I really found was a group of wires all tie wrapped together tight enough to leave grooves in the wire insulation. I started the car and let it run for about 20 minutes and those wires were to hot to touch comfortably. So I cut tie wrap and seperated the wires to givem a little air space. I'm just gonna leave the plastics off the steering wheel on my way to work tommorrow and monitor the area closely. Hopefully it was just smoke coming from the tie wrap due to the heat. I'll keep you guys posted and thanks for the quick replies on what to do. Oh and as for other electrical issues yes I am having them but it was before I noticed this. A friend of mine installed a cd player for me and it just so happened the same day my dash lights,fog lights, and the lights for the transmission hud don't work now. I wouldn't think the cd player would be in relation to those but I don't think he used the adapter to where everything just plugs together. Maybe a bad crimp? or crossedwire could cause this?
bullitstang1313
713
Aug 23, 2007
  • Aug 23, 2007
I imagine something he did caused a short in the wiring and now you have a burned fuse. That could be related to what you are seeing in the steering column. If he ran a power wire directly from the ignition switch to provide power the cd player and its shorted that could be your culprit. I would doublecheck his wiring.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2007
  • Aug 23, 2007
There was a FREE recall on Ford ignition switches. They overheat and sometimes catch fire. That burns up the steering column and sometimes the car interior. Since this is very old information, you may not be able to get the switch replaced for free anymore. The auto parts stores sell the switches for $13-$15.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the database, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28. They will not give the part so that you can install it. The rules of the recall are that they must install the switch to prevent any legal problems.
M
MoneygrubbinCar
155
Jacksonville
Aug 23, 2007
  • Aug 23, 2007
Thanks jrich I'll get on it tommorrow and get this thing fixed a.s.a.p as for now I'm driving with all the plastics around the wheel off pretty much to give it that really trashy look and keep me safe somewhat.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
