  • SN95 4.6L Mustang Tech
HELP! installing cams HELP!
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Mar 1, 2008
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Mar 1, 2008
  • Mar 1, 2008
im instaling cams how do get the gear off is ther a special tool i need i have the bolt off and the gear will move slighty but i cant get it to slide off completly
forum155pl
520
the 509
Mar 1, 2008
  • Mar 1, 2008
its prolly the chain holding it on.. your going to have to unbolt the cam and kinda pull the cam out of the sprocket, MAKE ssure that your buddy holds that cam gear with a couple sets of vice grips nice and tight man!
good luck
hotstang_46
481
Charlotte NC
Mar 1, 2008
  • Mar 1, 2008
it should come off.....no special tricks to it as I remember
forum155pl
520
the 509
Mar 1, 2008
  • Mar 1, 2008
he is doing it with the timing chain cover on, it sounds like the chain is just binding
like when you hold a bike chain out sideways you can move it around like a snake, is this the case?
98COBRA281
1,348
30
59
Mar 1, 2008
  • Mar 1, 2008
ya i doing i twith the front cover on, the chain is binding on the tensioners and i cant even get a little slack out of the tensioners
hotstang_46
481
Charlotte NC
Mar 1, 2008
  • Mar 1, 2008
well then ya, as forum said, you should be able to just take off the cam caps and do it that way..
use gloves be careful, those dam cams are sharp
98COBRA281
1,348
30
59
Mar 1, 2008
  • Mar 1, 2008
i finally got them in, then i found out that npi cams and pi cams have different cam bolts so i had to drive 20 miles to the juck yard and got them out of a police interceptor that had pi heads
C
charlesw6954
476
Mo
Mar 1, 2008
  • Mar 1, 2008
You should of took the PI heads.
98COBRA281
1,348
30
59
Mar 1, 2008
  • Mar 1, 2008
i was thinking about that but they been sitting out in hte open with no intake or hood so there in pretty rought condition and they were filled up with water today when i went there
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
