The first two codes here are the ones i'm having problems with, the other codes i know why they are poping up. The reason i was checking the codes is i just installed longtubes and during the process i smashed the map sensor, After which it idled a little funny and would lurch or just kinda wanna take-off while cruising around 60mph in 5th. So i replaced it today with one off of one my old 5.0 work trucks and then reset the eec and took it for a spin, came home and pulled these codes.
KOEO
95 (oc): Fuel Pump Monitor circuit problems, processor to pump motor ground. Suspect inertia switch, FP relay, harness.
I don't know why i'm getting this code , the fuel pump is working and everything has been working fine with it
KOER
42 (r): EGO/HO2S sensor voltage always above "rich" on bank #1 (c*): No EGO sensor rich/lean transitions detected, bank #1. 42 (c): 2.3 Turbo. EGO read rich for more than 15 seconds while in closed loop.
Can someone tell me which side is bank #1 so i know which 02 sensor to replace and which wiring to check please.
Other codes--All the smog stuff and appearently the egr has been deleted by the previuos owner.
KOEO
81
82
85
KOER
33
SEFI test
9
KOEO
?KOER
KOEO
81
82
85
KOER
33
SEFI test
9
