Help Me Choose: Tranny or Rear
NC85
100
Chesapeake, VA
I've got a bone stock 86GT(182K) that I plan on 1/8 mi. racing this year. I'm torn between doing the following first:
1. Buying a 3550 with bellhousing,shifter, and clutch (needs one)
2. Buying 31splines,T-loc,4.30s,driveshaft, and clutch(needs one)+90/10s,4cyl fronts, solid u/l, subframes, and welded boxes.
My budget is roughly 2K right now and I'm leaning towards option #1 due to its high initial cost.
Goal is to run at least 8.5(shooting for 12s) on 26X10.5X15 ET Streets with all the cheap mods. Also have 1-3/4"longtubes that I plan on installing last after #1 and #2 are complete.
So, what would you do first? Thanks.
Go with #2,you will notice more of a performance increase with the 4.30s, and the car really needs to have its suspension upgraded to put any power to the ground. A stocker t-5 will hold up for awhile, just buy an aftermarket shifter. My 89lx T-5 has held up for more than 2 years runnin 12.20s
One other thing, Id much rather have a transmission break than a axle, the damage would be alot less.
