Help me decide on heads
  • Thread starter Thread starter joeyd0730
  • Start date Start date Jan 21, 2007
joeyd0730
130
queens, ny
Jan 21, 2007
  • Jan 21, 2007
seems that my ported e7's with crane springs. are not cutting it anymore. i need some advice on which heads to purchase, the guy that tuned the car recommended victor jr heads. whats your opinions. the car made 390rwhp and 380 ftlps at the rear wheel on a mustang dyno with the stock heads, here is a list on eninge mods.
306 w/forged pistons
eagle crank and rods
dss windage tray
e cam, 1.7 rollers
efi spyder intake, s-trim making 12 lbs
42lb injectors. 80mm tb, 73mm mass air
my a/f is 11.5 across the board
thanks in advance for any help.
vikingpower
656
CWU Ellensburg, WA
Jan 21, 2007
  • Jan 21, 2007
Looks like you're already pushing the limit with your stock block. If you get heads you're going to need to upgrade to a better block as well
blackened88lx
Connecticut
Jan 21, 2007
  • Jan 21, 2007
/\ Agreed. Run 14psi for a little more power, but don't waste your money on a head swap that will turn your motor into a time bomb.
joeyd0730
130
queens, ny
Jan 21, 2007
  • Jan 21, 2007
yeah i hear you guys, i was hoping the girdle and arp bolts will hold me up till 500hp, well thats what i heard.
FoxBodyGT
71
Austintown, Ohio 44515
Jan 21, 2007
  • Jan 21, 2007
The girdle will keep the block together, but not intact, if that makes sense. Basically it will hold the two pieces together so there isn't a lot of internal carnage or exiting of parts, but the block can still split.
I'm with others, just turn up the wick a little or opt for a beefy block and the heads at the same time.
Chietala
111
Sacramento
Jan 21, 2007
  • Jan 21, 2007
You have a good tune and your fine with a set of heads.
blackened88lx
Connecticut
Jan 21, 2007
  • Jan 21, 2007
The girdle and bolts won't help the block any. If you put the heads on there and split the block, then you ruin the heads. Now you need a block and another set of heads. Either do a block and the heads, or run a little more boost and be happy. Don't risk ruining good parts unless you have money to throw away.
joeyd0730
130
queens, ny
Jan 22, 2007
  • Jan 22, 2007
when you talk about stronger block, are you guys refering to like a dss block? thanks for the replys.
Sicarius428
2,085
Jan 22, 2007
  • Jan 22, 2007
Correct me if I am wrong but my take on the DSS is just a dressed up stock block. They are referring to World Products, Ford racing(A4, R, Boss blocks) and the Dart. All of which will probably set you back 2k but are pretty good to 1000hp depending on which block you choose.
Kevin
Modular2v
3,222
23
99
oklahoma
Jan 22, 2007
#10
  • Jan 22, 2007
  • #10
it most likely be fine....but as everyone said, your running on borrowed time! my car is making close to 500hp and my block has not been phased yet. That being said it is a crap shoot.....some hold until 600, others break at 400
joeyd0730
130
queens, ny
Jan 22, 2007
#11
  • Jan 22, 2007
  • #11
I got it. it looks like to engine will come out again, reason i say this is during the tune anytime the car was reved passed 4500 rpm i had major blow-by from the valve covers. being i have the spyder intake there is no pcv valve, so i opted to vent the crankcase better by adding a second vent on the drivers side valve cover.
so i was told the rings didnt seat correctly. the motor only has 500 miles on it, could it be possible that the motor isnt broken in correctly and this is why i am getting the blowby? i know it wasnt the best thing to do but i have been running 5 quarts of syntetic oil and 1 quart of lucas since the rebuild. i have a 6qt pan. is there anyway that this could be causing the blowby? i was thinking of just running 6 qts of reg 10-40 and see the results. i did a compression test and the numbers are great. i am just throwing things out there to decide if i should pull motor, or just run with it till dooms day. i am edging towards a new block, but its a shame to get rid of this one being all the money dumped into the short block. i do have a great tune on the current motor. Thanks for all the input on this subject, joeyd
joeyd0730
130
queens, ny
Jan 26, 2007
#12
  • Jan 26, 2007
  • #12
time to start fresh, thanks again for the help
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Jan 26, 2007
#13
  • Jan 26, 2007
  • #13
its best to use dino oil during the break in period... stay away from syntehtics at that time.
vikingpower
656
CWU Ellensburg, WA
Jan 26, 2007
#14
  • Jan 26, 2007
  • #14
Ya, the oil needs to allow just enough friction so the rings can rub against the cylinder walls. When you're out looking at heads, go to TEA's website, they got some pretty wild CNC'd stuff on there
  • Locked
Expired 1992 Gt Supercharged 331 500 Rwhp Nj
  • 88GTtom
  • Mar 8, 2014
5K
Fox Body Mustangs For Sale (1979-93) Mar 8, 2014
88GTtom
  • Locked
Brand New 347 stroker, pan to custom exhaust
  • 304billet
  • Feb 1, 2012
  • Engine and Power Adder
2K
Engine and Power Adder Mar 2, 2012
304billet
  • Locked
F/S: *RARE* TROPICAL/MIMOSA NOTCHBACK COUPE
  • biznotchlx
  • Jan 27, 2012
4K
Fox Body Mustangs For Sale (1979-93) Jan 28, 2012
Twentz
T
W
HELP!! s/c 347 stroker rebuild good or bad idea
  • wheels15
  • Jun 9, 2011
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2011
revhead347
W
  • wheels15
  • Jun 9, 2011
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2011
wheels15
W
