help me decide on this intake
  • Thread starter Thread starter Roland69
  • Start date Start date Mar 27, 2007
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 27, 2007
  • Mar 27, 2007
I know a guy selling a Explorer upper and lower intake. The elbow and 65mm TB are still bolted on and also the EGR, ingectors, fuel rail, IAC, TPS. and some other little doo dadd's. Just wondering if it's worth me buying and is it really worth the little mods to it to get it to work on my car. He is asking $150 cdn for the whole unit...
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Mar 27, 2007
  • Mar 27, 2007
sounds like a great deal. make sure its the internal EGR model. with the egr ports in the lower that run thru the intake back up. easy way to tell is look for the small circle port in between each set of 4.
the only other mods are the vacuum lines. just some funky routing, but if u can weld grab a tig machine and drill and make it like stock.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 27, 2007
  • Mar 27, 2007
got a tig and welding is no issue
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 27, 2007
  • Mar 27, 2007
he also has a set of under drive pully's (minus the alt) a computer for mass air, dart head's <---are theese ant good
gunmetal5.0
144
Chico, CA
Mar 27, 2007
  • Mar 27, 2007
Dang Roland you can tig? PROPS 2 U. That sounds like a good deal. Maybe you can even sell your old intake to someone doing an EFI swap and make some money back.
V
v8only
2,378
22
49
Mar 28, 2007
  • Mar 28, 2007
that 65mm throttle body and spacer can't be used with your mustang. the throttle body can, but it takes a significant amount of modification.
the injectors will work great, the fuel rails won't. use the explorer injectors on the mustang fuel rail.
I don't believe the tps will work either.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Mar 28, 2007
  • Mar 28, 2007
the TB conversion is not that hard - there are instructions on my webiste in the tech section - use the Explorer TPS!!!!!!!!!!!!
JChalfan
551
Bellevue, WA
Mar 28, 2007
  • Mar 28, 2007
That sounds like a great deal, I'd jump on it in a second.
I've seen writeups for the throttle body conversion and it didn't look too hard. I may be thinking about the one at Tmoss's site.
If I remember correctly, the plugs on the explorer injectors are different than the mustang injectors. You can use them if you splice the correct plugs onto the car harness.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Mar 28, 2007
  • Mar 28, 2007
Some Explorer injectors use the very same connectors as the Fox - I run a set of Explorer 19# that required no coversion.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 28, 2007
#10
  • Mar 28, 2007
  • #10
thees injectors look longer but maby not....So should I just buy it and if I decide not to use it just clean it all up and put the complete setup on ebay
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 29, 2007
#11
  • Mar 29, 2007
  • #11
should I leave it and just save more and buy a TF or something better
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
