Help me decide.......
  • Thread starter Thread starter Phatt_daddy
  • Start date Start date Jul 30, 2005
P
Phatt_daddy
219
Hytop, AL
Jul 30, 2005
  • Jul 30, 2005
I am fixing to order a carb, return style fuel pressure regulator, and a cam lifter combo for my car and want some feed back on what works as far as fuel consumption and power. It is an '84 model lincoln engine with a .040 bore and stock stroke. I will be putting a stock aluminum 4 barrel intake and all I know is that I need at least a 600cfm carb. I am looking to spend about $500.00 shipping included from either Jegs or summit. What would be best. I want more power but not at my current 5-7 mpg I want about 15-19 mpg. Help me please.
Nate
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jul 30, 2005
  • Jul 30, 2005
Well Fat Daddy,
You are not going to get a serious increase that will give you a major "WOW effect" from a typical cam, intake and carb swap ... although it will be quite noticeable.
... Unless the car is running like a big pile of dog s hit .... in which event, just running efficiently will be WOW enough.
However, based on you general mpg, it sounds as if your current setup is fairly rich and unable to be adjusted down from this setting?
As you probably know, cylinder heads are the most determining factor in the WOW effect (in conjunction with other goodies) ... and from your input one assumes you are running low-ball factory heads.
Also, for you to input as to what sorta pistons you are running, as this will play a major role in what kinda lift/duration you can run for a cam without the valves and slugs (pistons) bumpin' into each other.
Without full knowledge of what you are running it is more difficult to give you a best solution ... somebody on here might tell you to run a cam bigger than what your setup can handle and then you end up with poor advice and are unhappy with the expendature of hard earned cash
More input would help me guide or persuade you better ... so you have an '84 lincoln engine ... what else ... what car ... what are we missing
P
Phatt_daddy
219
Hytop, AL
Jul 30, 2005
  • Jul 30, 2005
Thans cop, nuf said. Here goes............... it is an '84 lincoln engine bored .040 with flat tops, I think w/ 4 slight valve reliefs, that look like stock pistons except they have .040 stamped on them. Heads are stock lincoln, no porting no valve job no rollers nothing special. currently I am running my stock '87 model sd fuel injected setup that I am getting the 5mpg in. I have done some trading to get the wiring harness, intake, and ignition to carb my car so all I am out is the carb and dissy.my original engine went south on me as it started blowing oil out of the pcv hole and burning about 2qts of oil (20w50) a week. lost all power that it still had. I don't know much about this engine seeing as how I have never worked on one before until this car came around. since then I have swapped engines placed a new flywheel, clutch, pressure plate, throw out bearing, quadrant, and adj. shift cable. I just wwant the cae to perform like it should and I dont have the time nor the money to chase down the electrical of the problems in the car. Hope that is suffecient enuf to get a good reccomendation.
Nate
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jul 30, 2005
  • Jul 30, 2005
Since you are going to retain the stock '84 heads it might be wise to just buy better valve springs to handle a new cam without the possibility of the springs binding or floating when revved. Then we start getting deep into your budget.
Unfortunately for everyone on this site $500 bucks doesn't go too far when buying new parts.
However, you could look for someone that is selling used pieces at a substancial discount. You can find good parts that are just being sold because the previous owner is stepping up in the power game or has a change of heart.
The '84 lincoln heads are even more restictive than a stock HO head (E7 casting) ... this means an airflow bottleneck that will restrict top end performance dramatically ... but running at 5mpg is ridiculous. Buying big parts is not going to do much for a stock block and heads and make the car more unbearable to drive than you can imagine.
Your block is also non-roller, so a good hydraulic cam will be fine
Soooo, based on what you have here is what I suggest:
*New valve springs with around 110#'s closed and bind above .500" lift
*A cam and lifter set with about 268 duration and .450" lift with around 112* lobe seperation angle (perhaps a Crane set)
*Tried and true Edelbrock 302 Performer intake
*Tried and true Edelbrock 600cfm electric choke
Again, going bigger is not necessary as your heads are a major bottleneck.
Fuel pressure on a carb car will between 5-7psi ... with this mild setup you should be able to achieve around 16mpg average and still have good throttle response and mid-range power with a noticeable lope to the idle.
Good Luck
P
Phatt_daddy
219
Hytop, AL
Jul 31, 2005
  • Jul 31, 2005
Now then I might be switching to my old '87 heads. The 5-mpg was with the '87 engine in now that I got the '84 in I am not quite sure what my mpg is. The intake I am going to use will be a stock Ford casting aluminum 4-barrel. The fuel pressure regulator is a mallory #650-4307m or a 650-4309 out of jegs. As for the carb, I know you reccomended the edelbrock, but how good would a Holley be. I can get either for about $10.00 difference. I also plan on keeping the stock in tank fuel pump so I am also getting the fuel line fittings so that I dont have to cut my stock ones. As for the cam according to your recommendation how would the Lunati bracket master II #638-00064LK w/ 284 deg adv. duration and .488 gross lift. I am not looking for a serious WOW factor here, just something to give me a little more umph. After all I drive a stock '87 model with the stock 2.73 gear, a stock clutck kit, stock pressure plate, and except for the .040 bore, a stock engine.
Maybe a little later on once I can put in and get out the stock '87 block from the machine shop, we will be talking about porting, stroking, compression, and spring tention. Till then
Thanks,
Nate
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Aug 1, 2005
  • Aug 1, 2005
Phatt_daddy said:
....... As for the carb, I know you reccomended the edelbrock, but how good would a Holley be. I can get either for about $10.00 difference.......
Well it depends which Holley carb you are referring to ... the 650 double pumper with mechanical secondaries is a good carb and will provide more fuel with the secondaries open compared to the Edelbrock units (which supports making more power).
However the Holley vacuum unit is a throw away carb .. they work for a while, but need constant rebuilding and are known as a throw away carb or paperweight.
I recommend the Edelbrock because it will provide all the fuel your stockish engine can make and most people find them quite reliable and fuel efficient.
Phatt_daddy said:
....... As for the cam according to your recommendation how would the Lunati bracket master II #638-00064LK w/ 284 deg adv. duration and .488 gross lift. I am not looking for a serious WOW factor here, just something to give me a little more umph. After all I drive a stock '87 model with the stock 2.73 gear, a stock clutck kit, stock pressure plate, and except for the .040 bore, a stock engine.....
This cam is a little big for your setup and will be a slouch down low, yet want to bring the power on late in the rpm range where your factory heads and intake are not going to be able to provide the flow that it will demand. So it will be doggish down low by not providing good air flow velocity (lazy air) and then when it wants a big gulp of air in the upper range the heads will choke it too much.
Also with the 2.73 azz in your car, it will take forever for your engine to even make it into the operating range of the cam.
I've had stockish cars with 268 grind cams in them and they had real gruff midrange power Also, don't compare the lift of a hydraulic tappet cam to that of a roller hydraulic tappet cam ... the roller tips allow for a cam to be cut with taller lobes on them ....
Remember, bigger is not always better ... a well matched engine combo will spank a poorly matched combo 9 out of 10 times
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Help Me Build a 289
  • 66Stang1
  • Sep 18, 2025
Classic Mustang Specific Tech Sep 18, 2025
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
