mackey said:
r.t .896
60' 2.48
330' 6.629
1/8 10.072
MPH 70
1/4 15.547 @ 90.40
run2
r/t 1.133
60' 2.624
330' 6.715
1/8 10.178
MPH 70.50
1/4 15.650 @ 89.28
Do I Possibly have a 14.999 run in the car?...
My car was an AODE. When I ran it it weighed 3420lbs. I ran 10.0 @ 73 with 2.2 - 2.3 60' short times. It had the air silencer removed and a K&N. I removed a little weight, added underdrives and gutted the cats and it went 9.5 @ 76 with 2.1 -2.2 60' short times.
Generally a car on street tires that has mild spin upon launch will have a slightly higher mph then say the same car with the same launch on stickies without bog or tirespin. This is not saying spinning is good at all just something to pay attention to. Generally there is a mph to match a certain E.T. (this can vary between heavy or lighter cars then normal, cars with poweradders and "all motor" cars) Your mph looks lower not higher which could indicate a heavy car, slow shifting, and/or out of tune. Someone asked you if your car was a vert because of the weight. I would stop by a scale and grab a weight of your car without you in it or with you in it and subtract your weight. This will just give you a baseline of where your car stands now and you can compare it to later when and/or if you decide to mod it more.
Weight plays a big part in E.T. and MPH.
Now your car has Flowmaster mufflers, CAI, and K&N so compared to my car with the K&N and Air silencer removed, you ran a 10.0 @ 70 mph while my car ran 10.0 @ 73 mph. Generally a car with a manual transmission will have a higher MPH then a automatic transmission car. Also some tracks may have a slight difference in times and mphs and also tracks can vary for elevation, temp., humidity and track surfaces. (the track closest to me (1/8th) usually has a slightly higher mph then the closest 1/4 track) Our cars compared... My aode vs your standard with the same e.t. but different mphs could be slow shifting and too easy launching on your part. Practice, Practice and more Practice will net you better 60' times and get you better E.T.s with a higher mph.
Your 60' is your race, bottom line. I have said this before and will say it again: You can have all the power in the world but if you can't get it to the ground, your going nowhere. I would suggest some stickys ( I like ET DRAGS ) and hard launching along with some fast shifting.
Good luck bud, hope you were able to get some info out of this.
I will be taking my car to the track (1/4 mile) in the morning to see how it does with the new Tremec in there.
