help me get my reverse lights to work
Lawbreaker5.0
543
Texas
so my reverse lights haven't worked in awhile. From what i can remember, they stopped working when i had a transmission put in. (way before i knew anything about cars)
What i've know/tried.
-so the bulbs aren't burned out.:D:D
-no power to either bulb
-put in reverse and check continuity between post/yes
-i get power to the switch (can't remember color)
i need help with any diagrams or procedures.
thanks
So you have power to the switch and continuity from one pole to the other. Does power leave the switch while reverse is engaged?
If so, check the wiring at a given reverse light. You might have a cut wire between the switch and back of the car.
How exactly do i check if power leaves the switch?
Which pole do i check? or which wire to i probe?
i wish i knew the actual way the current runs in through the switch and and out to the lights/
i thought jricher has wiring diagrams for everything. :D:D
You said you checked power into the switch and continuity across the switch, so you've seen the switch. There are only two wires.
With the key on, engine OFF, Emergency brake ON, car in reverse, check for power at both wires. If you have it, the issue is between the switch and the lights. Power goes straight from the switch to your lights.
If you don't have power at either wire, the source for powering the circuit is where I'd look. Make sure fuse 5 is ok.
Almost everything...
Don’t assume that both bulbs can’t be burned. Out. Check both of them
Then check the fuse...
Then check the backup switch...
The Tremec 3550 puts the switch in the same location as the T5.
attachment.php
The backup switch wiring connector has 2 contacts that push on the 2 studs that stick out of the top of the switch.
The power side of the connector will be 12 volts anytime the ignition switch is in the Run position. No 12 volts and you have problems with a fuse or the wiring
The lights side will be 12 volts when the ignition switch is in the Run position and the transmission is in reverse. No 12 volts on the lights side and the switch is bad
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
just wanted to let the guys who help me know that i got the reverse lights working tonight. The power wire came loose from the connector. i had to pull the wire out and soder it back and i worked like a charm. thanks guys
