  • SN95 4.6L Mustang Tech
help me please. clutch?
  • Thread starter Thread starter imblown-ru
  • Start date Start date Dec 19, 2005
1 of 2 Next Last
imblown-ru
247
Roanoke VA
Dec 19, 2005
  • Dec 19, 2005
I was goin down the road today and a 04 stang came up beside me with an exchaust and stuff, so i had to let him know what was up, and at about 85 mph...i guess the top of third gear, full throttle, the car just looses power almost like it hits a rev limiter. heres my thoughts....1) belt slipping 2) spark missfire 3) clutch slipping. This is an 02 mustang gt with paxton 1000 kit. on the stock clutch, but only 10,500 miles on the car. any input is great. thanks alot.
ps this is not the first time it has done it, and it will do it pretty consistently at WOT and high rpms.
M
mustanggt3685
130
Illinois
Dec 20, 2005
  • Dec 20, 2005
What about your fuel system? Maybe a clogged fuel filter?
imblown-ru
247
Roanoke VA
Dec 20, 2005
  • Dec 20, 2005
evening bump
sgarlic
3,085
Dec 20, 2005
  • Dec 20, 2005
Wow.. hard to judge based on the info provided.. do you have a dyno run with a/f graph that you could post? I'm wondering if perhaps you're detonating, or running very lean or something. Bad gas maybe?
40th GT
916
Lawrenceville, GA
Dec 20, 2005
  • Dec 20, 2005
Did the RPM fluctuate? Or was it just a feelin of lost power? Did you hear any noises other than normal engine noise?
E
exindust
329
Moorpark, CA
Dec 20, 2005
  • Dec 20, 2005
yeah take a drive with a predator and see how your fuel readout goes
imblown-ru
247
Roanoke VA
Dec 20, 2005
  • Dec 20, 2005
it has no mods to it besides the paxton kit, and the ecu was tuned by diablo for the kit. i havent altered it in any way.
imblown-ru
247
Roanoke VA
Dec 20, 2005
  • Dec 20, 2005
it doesnt make a noise. i dont hear any scary noises from the engine. feels like a fuel cutoff on a turbo car or something.
E
exindust
329
Moorpark, CA
Dec 20, 2005
  • Dec 20, 2005
quoted for emphasis amnit:
imblown-ru
247
Roanoke VA
Dec 20, 2005
#10
  • Dec 20, 2005
  • #10
which would involve me getting a predator
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 20, 2005
#11
  • Dec 20, 2005
  • #11
This is the reason why I don't race on street anymore. Or race in general. I'll usually brake something..
May be your loosing compression? Since its consistant issue? But I think its clutch myself. Is it the stock clutch? Pull the trans out and check it out
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 21, 2005
#12
  • Dec 21, 2005
  • #12
ahhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!1111
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 21, 2005
#13
  • Dec 21, 2005
  • #13
mity2
Jul 24, 2003
2,872
StateCollege PA
Dec 21, 2005
#14
  • Dec 21, 2005
  • #14
A
AntiRice98
158
#15
  • Dec 21, 2005
  • #15
you might be out of gas...sounds like the same thing i went threw when i first bought mine...it was doing the same thing and i didn't know what was wrong cause my gas gauge said i had 3 quarters of a tank (obvisley its broken) but shure enough i was out of gas...
imblown-ru
247
Roanoke VA
Dec 21, 2005
#16
  • Dec 21, 2005
  • #16
lol noo i dont think i was out of gas. my guage is right on. always has been. i guess what would help me is WHEN DO OUR CLUTCHES START TO SLIP? what power levels? thanks
trailblazr81
571
Hollister, Cali
Dec 21, 2005
#17
  • Dec 21, 2005
  • #17
Hmmmm... Now I dont claim to be an expert n know it all, but I would think if it was clutch you would have had the problem earlier than WOT in third. Somewhere in first and second when you were hitting same RPM it should slip.
mity2
Jul 24, 2003
2,872
StateCollege PA
Dec 21, 2005
#18
  • Dec 21, 2005
  • #18
Dude... ur running Supercharger. I don't know your driving habit, but by the sound of it, you ride your car hard time to time. Your running stock clutch right? Stock clutch is not that strong. It can last for a while, or could become inadequate right after first WOT after positive manihold pressure device was added. I'm slightly in shock that after spending all this money in supercharging your car, you never thought to add stronger clutch....
Because you know, I would have if that was mine.
My suggestion is pull the trans, and check your clutch. Or just install new one. But I would stay away from SPEC
imblown-ru
247
Roanoke VA
Dec 22, 2005
#19
  • Dec 22, 2005
  • #19
mity2...thanks for the advice. but im a college student, and just bought the car 2 months ago. a clutch is the first thing on my list once i sign my sponsorship contract. i was just wondering if this is a more serious thing i should look into.
D
Dave Holman
72
#20
  • Dec 22, 2005
  • #20
I don't think it is your clutch and I certainly wouldn't go the trouble of pulling your tranny until your sure it is necessary. I don't think a worn clutch will make your car feel like it is hitting the rev limiter. If you have the means to do so, I would check the computer for codes and check the a/f ratio across the entire rpm band.
If I were fortunate enough to have a supercharger, I would take whatever steps necessary to ensure this thing is not running too lean. This condition will blow up the stock motor.
1 of 2 Next Last
N
High Hanging Rpm Issues(2004 Gt)
  • nogripcal
  • Jun 16, 2017
25K
SN95 4.6L Mustang Tech Dec 7, 2020
BGberg31
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
87 Gt (5.0 H.o.) With 88 T-bird Motor (5.0 Non H.o.) Please Read And Help!!!
  • NCsProdigy 87GT
  • Jan 17, 2016
4K
Fox 5.0 Mustang Tech Jan 18, 2016
jrichker
U
  • Locked
Expired 1988 Fox Notch With A Termi Swap And Tt
  • undfetd
  • Dec 16, 2014
6K
Fox Body Mustangs For Sale (1979-93) Dec 16, 2014
undfetd
U
