HELP ME PLEASE
  • Thread starter Thread starter mellemel
  • Start date Start date Feb 18, 2008
mellemel
Michigan
Feb 18, 2008
  • Feb 18, 2008
i am rebuilding my engine and am buying new pistons. i want a higher compression thinking about 10:1 compression ratio. I will be running 93 octane pump gas. i have stock heads on my 1991 302 lx. is this too much compression for a mostly street car and will hypereutectic be okay or do i need forged. thinking about keith black kb116 pistons. thanks for the help. i was going to buy new heads but when car was taken apart we realized it needed to be rebuilt so the money for heads is now going to the rebuild process.
NKau
1,346
Jefferson, WI
Feb 18, 2008
  • Feb 18, 2008
If you really want to make a bit more power, I'd spend money on some better heads as opposed to putting cash towards raising your compression and keeping the factory heads. It's a different story if your shortblock NEEDS to be rebuilt first, and you plan on adding better heads in the future though.
mellemel
Michigan
Feb 18, 2008
  • Feb 18, 2008
car does need to be rebuilt heads were going to be bought but when i took it apart pistons had cracks in them. the money was going to be spent on some AFR 185's but the rebuild must come first.
PUNISHER RACING
1,124
FORD CITY, PA.
Feb 18, 2008
  • Feb 18, 2008
I use the KB 116'S and like them just keep your revs below 7,000 and the power adders on the low side
P
PJC Racing
199
  • Feb 18, 2008
I prefer forged, but the hypers will be fine for your combo. As for the 10:1, it will be fine on on the street with 93 oct. Just make sure your tune is good and I would go one heat range lower on the plugs.
mellemel
Michigan
Feb 18, 2008
  • Feb 18, 2008
do you use your pistons with stock heads punisher racing?
57fairlane
560
Oakwood, GA
Feb 18, 2008
  • Feb 18, 2008
I would at least get the heads ported or run some gt40s.
personally I wouldn't bother with the shortblock.
You can mill up to .060" off e7s without warping them under load and just run some .029" cometics.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
M
Please help me identify this.
  • MattyB77
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 4, 2026
gkomo
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • Mindseye007
  • Aug 16, 2026
Mindseye007
