HELP ME PLEASE
mellemel
Michigan
i am rebuilding my engine and am buying new pistons. i want a higher compression thinking about 10:1 compression ratio. I will be running 93 octane pump gas. i have stock heads on my 1991 302 lx. is this too much compression for a mostly street car and will hypereutectic be okay or do i need forged. thinking about keith black kb116 pistons. thanks for the help. i was going to buy new heads but when car was taken apart we realized it needed to be rebuilt so the money for heads is now going to the rebuild process.
If you really want to make a bit more power, I'd spend money on some better heads as opposed to putting cash towards raising your compression and keeping the factory heads. It's a different story if your shortblock NEEDS to be rebuilt first, and you plan on adding better heads in the future though.
car does need to be rebuilt heads were going to be bought but when i took it apart pistons had cracks in them. the money was going to be spent on some AFR 185's but the rebuild must come first.
I prefer forged, but the hypers will be fine for your combo. As for the 10:1, it will be fine on on the street with 93 oct. Just make sure your tune is good and I would go one heat range lower on the plugs.
