  • SN95 4.6L Mustang Tech
help me please!!!!!!
  • Thread starter Thread starter fossil
  • Start date Start date Oct 10, 2010
F
fossil
washington
Oct 10, 2010
  • Oct 10, 2010
Ok so i got two questions i have a 1996 mustang gt that my reverse lights dont work and i was trying to hook it them up to a toggle switch if someone could tell me how please the reason for the toggle switch is because the fuse for the reverse lights keeps blowing and i cant find the short or where the wire is grounded so if someone can tell me how to hook them up to the toggle switch it would be great.
ok next question i have a 2001 mustang v6 that the coil pack went out so i changed it and the spark plugs and wires but its still running bad if anyone has any ides i would really like to hear them thanks to all who read this and post back.
2006KJ
128
North West PA
Oct 10, 2010
  • Oct 10, 2010
all a motor needs to run is fuel, spark, and air. make sure it has all those and go from there. Check all plugs for the correct gap, make sure all the plugs/wires/coils are tight and not corroded. Make sure the air filter is not plugged. If one coil pack is fried most likely there are more fried. Reverse lights... start at the bulb and work your way forward. find the ground and live wire coming from the bulb.. then follow them to find the short. a Test light would be your friend there. Also some bulbs around themselves in the bulb socket.. make sure it's a tight fit and the contacts are clean/shinny.
F
fossil
washington
Oct 11, 2010
  • Oct 11, 2010
help still needed
ok so i looked at the wires but i dont know where to start looking to find where to splice the wire in to hook up to toggle switch. i really need help i cant drive my car on post without revers lights thanks
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
