help me spend $1000
  • Thread starter Thread starter robertdeuce
  • Start date Start date Jul 22, 2011
1 of 2 Next Last
robertdeuce
147
  • Jul 22, 2011
i just got a $1000 dollars from the government in taxes. so i looking to upgrade some stock parts.
the only non stock parts i have are 3.55 gears and an mgw shifter.
can anyone tell me what other things i can get performance wise for my 89 gt convertible?
what are must haves?
thanks
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 22, 2011
  • Jul 22, 2011
Headers+exhaust and an aftermarket MAF, remove the air silencer and put a good panel filter (K&N) in it. Weld in sub frame connectors would be a good idea for a convertible, too.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jul 22, 2011
  • Jul 22, 2011
hookers and blow
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Jul 22, 2011
  • Jul 22, 2011
full length sub frame connectors and suspension!
1989DropTop
269
18
29
Eatonville Washington
Jul 22, 2011
  • Jul 22, 2011
Subframe connectors, headers, off road x or h pipe, suspension
Cobra912
1,777
11
39
Wish I was anywhere but here
Jul 22, 2011
  • Jul 22, 2011
well I can help you I know where you can find some sweet edelbrock heads, headers, etc
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,134
224
Massachusetts
Jul 22, 2011
  • Jul 22, 2011
Sn95 5-lug conversion and sn95 wheels
ReefBlueHatch
682
96
39
Central KY
Jul 22, 2011
  • Jul 22, 2011
SteedaGT9150 said:
hookers and blow
Headers and forced induction?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 22, 2011
  • Jul 22, 2011
Being that your other current post is about the fact you can't pass emmision testing because of a rotted exhaust system, I would say, Ford Racing shorty headers, a good cat converter H pipe and your choice of mufflers. That will eat up your $1000 pretty well and leave you some small change to go to buy a Big Mac, a soda and an order of fries...
Ford Racing Stainless Steel headers $250 http://www.summitracing.com/search/?keyword=ford racing headers&dds=1
Catalytic converter H pipe $350-$500 http://www.latemodelrestoration.com...g-50L-Bbk-Catalytic-H-Pipe-For-Shorty-Headers
New mufflers and exhaust pipes - $300-$500 http://www.latemodelrestoration.com/products/Mustang-Catback-Exhaust-Systems
robertdeuce
147
#10
  • Jul 23, 2011
  • #10
emissions is taken care of. i dont wanna waste money in an exhaust setup that i dont want just to pass emissions.
im liking the sub frame connectors, maf and full exhaust suggestion. maybe some suspension parts.
i wish the sn95 conversion and the wheel were 1000.
should i replace the stock clutch and flywheel?
Rick 91GT
Mustang Master
95
99
PA
Jul 23, 2011
#11
  • Jul 23, 2011
  • #11
You only need to replace the stock clutch and flywheel if it is worn out and needs to be replaced. Check your PM's.
Boosted92LX
5,721
4,244
224
Jul 23, 2011
#12
  • Jul 23, 2011
  • #12
Man, subframe coneectors aren't that expensive...at this point, if I got a windfall like that, I'd be cruising the classifieds at corral or craigslist to find a blower or turbo kit. You can get the less expensive stuff a piece at a time later...
If you don't want forced induction, look for a good set of used heads or another large money item.
1bad67sbf
674
N. VA
Jul 23, 2011
#13
  • Jul 23, 2011
  • #13
what about the gt40 top end setup?
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jul 23, 2011
#14
  • Jul 23, 2011
  • #14
Yup, this is how i would spend the money.
citmov
632
12
49
Chi-town
Jul 23, 2011
#15
  • Jul 23, 2011
  • #15
I like Nikwoa's suggestion.
Btw why do u think the sn95 conversion and wheels aren't $1000? It's doable if ur using used parts. Check the stickies under 5 lug conversion.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jul 23, 2011
#16
  • Jul 23, 2011
  • #16
My mailbox...
robertdeuce
147
#17
  • Jul 23, 2011
  • #17
what kind of wheels are you talking about? im talking about the saleen replicas
FastDriver
I was uncomfortably high & wearing a helmet
Sep 5, 2001
6,241
2,949
224
Vass, NC
Jul 23, 2011
#18
  • Jul 23, 2011
  • #18
Nik is on the money, as usual. If you go with used parts, you'll get all of it done and still have a little money left over.
If you can find a deal on an explorer, Cobra, or GT40 intake, that's damn good bang for the buck, too. I'd definitely go with exhaust mods first, though.
I don't personally think a lot of money should be paid for subframe connectors when you can just go to a machine shop and have them made for next to nothing.
If I were starting from scratch and going part by part again, it would be in this general order:
ten-minute tune up (remove air-silencer, 14* base timing, remove dog-bone, remove spare, remove sway-bar)
K&N panel filter
Pullies (w/o alternator pulley unless you're running a 3G)
Subframes
Shifter (Stock sucks)
full exhaust (w/ long-tubes)
gears/new clutch packs (don't forget the friction modifier)
Intake/TB/MAF
springs/shocks/air-bags
Torque boxes
Axles/5-lug swap/disc brakes all-around
Drag-Radials/Slicks-Skinnies
Fuel-pump/AFPR/MSD ignition
Clutch/Transmission/scattershield (or when the T5 blows)
Heads/Cam/rockers + n/a tune
Nitrous(125-150 shot)/F.I. (8-12lbs boost) + FI tune (500rwhp or less with conservative tune and 6000 RPM cap)
I'll let the guys pick this apart and add stuff that I missed, but this is the cookie cutter layout for me
I'm not a big believer in the aluminum driveshaft or flywheel, though I've had the D/S. I'm also no longer a big advocate of electric fans. All of these things might yield some advantage, but they're incidentals to me that I wouldn't add until after I've done everything else and still wanted a little more.
Good luck in your build,
Chris
betke76
20+ Year Stangneter
Oct 23, 2004
241
9
laurel, md.
Jul 23, 2011
#19
  • Jul 23, 2011
  • #19
subframe connectors, exhaust, underdrive pullies
robertdeuce
147
#20
  • Jul 23, 2011
  • #20
great list fastdriver, i really appreciate it. i really wanna start upgrading the performance parts as i just finished buying interior stuff.
if anybody has anything to add please do so, i will save the list to my favorites
for future purchases
1 of 2 Next Last
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Is the BOSS 302 block oem compatible with the 95 302?
  • saf_blu302
  • Aug 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 2, 2025
revhead347
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
9
Engine 2.3 fox body upgrades from sn95
  • 92ponyboy
  • Feb 20, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 25, 2026
NXcoupe
N
