  • SN95 4.6L Mustang Tech
Help me spend $800
  • Thread starter Thread starter Pimp03GT
  • Start date Start date Jan 20, 2004
P
Pimp03GT
  • Jan 20, 2004
I have an 03 GT, and $800 burning a hole in my pocket... What would you guys suggest spending it on to wake my car up? I have a bassani x w/cats and 40 series flows on stock catback right now.. Thats about all thats worth mentioning. Help me out...thanks
Beau
3,050
San Diego
Jan 20, 2004
  • Jan 20, 2004
shifter and some gears, and if you have money left over, pullies and a timing adjuster.
spree
294
los angeles
Jan 20, 2004
  • Jan 20, 2004
if you want to work on your suspension, i'd get some new shocks/springs
if you want to get more power, i'd get some 4.10's, short shifter, plenum, (and if you have anything leftover) pulleys and a t/a.
** edit - oops, you said you wanted to wake up the car...ignore the suspension stuff
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Jan 20, 2004
  • Jan 20, 2004
shifter, gears and springs
menasci
640
Chandler, AZ
Jan 20, 2004
  • Jan 20, 2004
4.10's
and a shifter (Triax or Pro5)
G
gdear66
46
Memphis, TN
Jan 21, 2004
  • Jan 21, 2004
Definitely the rearend gears and shifter first (best bang for buck). I'd say u/d pulleys after that. Then change out the TB, plenum, and CAI. Look on ebay for the stuff before you buy anywhere else. You can find this stuff cheaper there.
V
VetteKilla03
22
Corpus Christi, TX
Jan 21, 2004
  • Jan 21, 2004
I would definitely go with gears and a shifter. If u do a lot of driving 4.10's might be too high....maybe 3.73's if u drive a lot. By a lot I would say 50-100 miles/day. Gears are definitely the best bang for the buck, and its a difference that is noticeable.
decoy562
1,526
Acworth, GA
Jan 21, 2004
  • Jan 21, 2004
This sounds like a good start. If you install the pullies and T/A yourself, you might be able to do all of it for $800, depending on how much you shell out for the gear change.
Blue 98 GT
56
Richmond, TX
Jan 21, 2004
  • Jan 21, 2004
I say gears all the way. While you're in there you might want to consider beefing up the rear end too with some bigger axles and a new diff. it will save you lots of money later.
and as far as gears go...
I have never heard a complaint about putting 4.10's in.
I have heard people who put in 3.73's say they wished they would have put in 4.10's
And installing 3.55's are a waste because if you dont already have them, you have 3.27's which are too close to justify a swap.
Sleepy1
807
Chicago, IL
Jan 21, 2004
#10
  • Jan 21, 2004
  • #10
Gears, pullies, and a new shifter (not really a speed item).
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • Gulftown980x
  • Jul 29, 2026
squeak93
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
