Help me spend $800
Pimp03GT
I have an 03 GT, and $800 burning a hole in my pocket... What would you guys suggest spending it on to wake my car up? I have a bassani x w/cats and 40 series flows on stock catback right now.. Thats about all thats worth mentioning. Help me out...thanks
if you want to work on your suspension, i'd get some new shocks/springs
if you want to get more power, i'd get some 4.10's, short shifter, plenum, (and if you have anything leftover) pulleys and a t/a.
** edit - oops, you said you wanted to wake up the car...ignore the suspension stuff
Definitely the rearend gears and shifter first (best bang for buck). I'd say u/d pulleys after that. Then change out the TB, plenum, and CAI. Look on ebay for the stuff before you buy anywhere else. You can find this stuff cheaper there.
I would definitely go with gears and a shifter. If u do a lot of driving 4.10's might be too high....maybe 3.73's if u drive a lot. By a lot I would say 50-100 miles/day. Gears are definitely the best bang for the buck, and its a difference that is noticeable.
1990StangLX said:
shifter and some gears, and if you have money left over, pullies and a timing adjuster.
This sounds like a good start. If you install the pullies and T/A yourself, you might be able to do all of it for $800, depending on how much you shell out for the gear change.
I say gears all the way. While you're in there you might want to consider beefing up the rear end too with some bigger axles and a new diff. it will save you lots of money later.
and as far as gears go...
I have never heard a complaint about putting 4.10's in.
I have heard people who put in 3.73's say they wished they would have put in 4.10's
And installing 3.55's are a waste because if you dont already have them, you have 3.27's which are too close to justify a swap.
