  • SN95 4.6L Mustang Tech
Help me with a nitrous system!!
  • Thread starter Thread starter Maza4ever14
  • Start date Start date Jun 13, 2005
Maza4ever14
187
Bay Area, CA
Jun 13, 2005
  • Jun 13, 2005
hello again! i got my 4.10s ordered yesterday (FRPP) and now im onto the next mod.
now im going for that easy power: nitrous.
i dont know jack squat about nitrous except from what i seen in movies.
what is a good nitrous set up? Wet or Dry? im dont wanna do any mods to the block, pistons, or any internals so what would be a safe system?
and round how much would i be spending?
Tony01GT
487
Orland Park, IL
Jun 13, 2005
  • Jun 13, 2005
get Nitrous Express efi kit(wet), with all the goodies in the upgrade kit, you can safetly run a 100 shot on stock internals, i ran 150 on my stock block but do not reccomend it. you will wanna run lower timing a few degrees or just use like a 101oct race fuel for the spray.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
  • Jun 13, 2005
i'd say about 800-1k$, install is easy, if you don't feel confortable with it pay someone.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 13, 2005
  • Jun 13, 2005
i would go with a wet system. you should run forged pistons with NOS. its a good idea to upgrade ignition system so you can have a retard control when on the juice. 2 degrees retard for every 50hp. and upgrading a fuel sytem isnt a bad idea when you are on juice either. as for cash u can spend as much as you want or as little.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
  • Jun 13, 2005
tips:let the motor cool down after runs, use it wisely(not messing around), get a rpm window switch or wot switch, always leave it unarmed while doing burnouts, then purge and stage!
Tony01GT
487
Orland Park, IL
Jun 13, 2005
  • Jun 13, 2005
oh and colder plugs!! I'd say 1-2 degrees non-platnum
Tony01GT
487
Orland Park, IL
Jun 13, 2005
  • Jun 13, 2005
with a wet kit you can safetly run 100 shot on stock fuel system
Maza4ever14
187
Bay Area, CA
Jun 13, 2005
  • Jun 13, 2005
wow thanks, i was also leaning torwards NX system too.
also how would i lower the timing by a few degrees?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 13, 2005
  • Jun 13, 2005
if you get a msd digital 6 ignition box it has timing retard switch which gets wired into the NOS system or get a timing light lossen distributor and retard 2-4 degrees. then tighten distributor back down.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
that wouldn't work considering 99+gts do not have distributors, haha, get a steeda timing adjuster and pullies while your at it.
Maza4ever14
187
Bay Area, CA
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
got the pulleys (BBK) already and i was eyeing a BBK timing adjuster kit but i know steeda makes better products.
is the adjuster kit an easy install and at what degree should i set it at?
Maza4ever14
187
Bay Area, CA
Jun 13, 2005
#12
  • Jun 13, 2005
  • #12
ok i just checked out steedas site and it was 139.
i also noticed it said this
We went the extra mile designing this part, to make sure it will fit with Steeda underdrive pulleys or Vortech and Paxton superchargers
would it work with my BBK pullies?
thanks again
Tony01GT
487
Orland Park, IL
Jun 13, 2005
#13
  • Jun 13, 2005
  • #13
if bbk are piggy back style then no, if they are not then yes.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
#14
  • Jun 13, 2005
  • #14
you can use the TA with the superchargers but will have to ditch the pullies.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
#15
  • Jun 13, 2005
  • #15
very simple install, i'd set the timing back 1-2 degrees for every 50hp incrament.
Tony01GT
487
Orland Park, IL
Jun 13, 2005
#16
  • Jun 13, 2005
  • #16
i gotta go, if you have anymore ?'s pm me.
stanggt00
371
baltimore md
Jun 13, 2005
#17
  • Jun 13, 2005
  • #17
i also have nx its easy as hell to install on the 99+ cars no vacuum lines problems like i had with the nos kit on my probe gt
and like every one said get all the safe stuff to help protect your motor
once i hit the dyno i will be adjusting every thing for 75shot on the street and 100shot for the track
and with a set of tires and suspension set-up its an easy 12 sec car if not better
ps get a bottle warmer if u want to see the full potental of your kit
600-800psi = hmm is that it and 950-1050psi = big ass smile believe me 600psi run and a 950psi run are like night and day
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
