Help me with header clearance!
Leezure
104
I have Kooks L/T headers which, when the car is empty, give me exactly 2 inches of clearance to the ground. They hit whenever I encounter a bump in the road.
I have Eibach pro springs on the car which look great but do not help in the clearance department.
My struts are old and I would like to replace them with a stiffer unit to control the spring compression so let me know which ones you would go with.
Here are my options as I see them:
1. Go back to the original front springs.
2. spring spacers
3. Motor mount lift
4. Skid plate
What would you do?
Do you have drop motor mounts? I have sportlines, and I never had header clearance problems until I installed the QA1 k member which lowered the car another 1/2" or so. Now my headers are flat on the bottom from hitting the ground. My next mod is gonna be a set of coil overs...
BTW, I did get your email, just didn't get time to respond til now. :)
