  • SN95 4.6L Mustang Tech
Help Me With My Cooling Issue!!!!
  • Thread starter Thread starter SRT Handz
  • Start date Start date Aug 10, 2008
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Aug 10, 2008
  • Aug 10, 2008
Ok, i have a Major Issue on My hands and need some Help....
Just so you know, my Autometer Temp gauge is reading off driver's side Drain Plug in the Block.
So today i go for a 20 Miles drive on the Freeway. I drove the entire drive at 90MPH and was just below 3K RPMs
As i drove i noticed the gauge got almost to 250 Yet my stock gauge didnt move. Once i reached my destination the Autometer gauge was still at 240ish so i popped my hood and opened the Overflow Tank just to find out that the coolant in the overflow tank was not even Hot....it was just warm. I was able to stick my finger inside the coolant and it didnt even hurt me....This made me worry. I then drove home and the same thing happened, Autometer gauge said 240 and when i got home the coolant in the Tank was just "Warm".... I wouldnt even consider it Hot because i could stock my finger in it.
So i starting thinking what it could be and i could only think if 1 thing..... The T-Stat!! Could all this BS be caused by the T-Stat. The only thing i could think of is that the T-Stat isnt Opening enough so the coolant in the motor is getting REALLY hot (Hence the Autometer gauge showing it because its reading from the block).
So Is My T-Stat Stuck Open or Is there another Issue at hand?
BurningRubber
1,865
24
58
Aug 10, 2008
  • Aug 10, 2008
Definatly possible the t-stat is sticking partially closed.
If it happens again, check the hoses and see if the lower seems extra pressurized, and see if the upper seems under pressurized.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Aug 10, 2008
  • Aug 10, 2008
yeah it sounds like you t-stat is stuck closed, or opening only a little, take it out and boil it in a pot of water to see if it opens....
mustang50v8
548
847 Chicago Burbs
Aug 12, 2008
  • Aug 12, 2008
agreed, sounds like it is stuck closed.
if it was stuck open your engine would run really cool all the time which is bad too.
62thunderbird
31
Nor Cal
Aug 12, 2008
  • Aug 12, 2008
I had that same issue it was my T-stat it got stuck open a lot and closed a lot. and it always ran cold or very hot. I went ahead and replaced it and runs great now. I also had to replce my intake manifold it was cracked and the old owner used house water plumbing pipe as the temp guage sensor out let. where the sensor screwed into. Got that all fixed too. T-stats are not expensive so just replace it.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Aug 12, 2008
  • Aug 12, 2008
bro ur so cool all you gotta do is put ur hand on the motor to cool it down
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Aug 12, 2008
  • Aug 12, 2008
Handz, please let us know how you find/fix the problem. Most def good for research
mransr
1,188
36
98
Riverside, SoCal
Aug 12, 2008
  • Aug 12, 2008
+1 on a bad thermostat...you've got the classic signs of it being bad
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
Aug 15, 2008
  • Aug 15, 2008
SOLUTION
Purchased a new stock T-Stock and gasket from Ford. Before installed the new T-stat i test both in boiling water...the Original T-Stat BARLEY even cracked while the new one open wide....so that was the issue.
Ordered a Mushimoto Aluminum Radiator to help out
BurningRubber
1,865
24
58
Aug 15, 2008
#10
  • Aug 15, 2008
  • #10
Glad it was a simple fix.
9
95StangMan
72
Santa Rosa, CA
Aug 15, 2008
#11
  • Aug 15, 2008
  • #11
make sure your fan is turning on...if your fan isnt turning on that could cause it to run hot too. my car wasnt getting super hot but it was running warm. i had a bad connector and ended up having to replace the whole fan. good luck
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
