Help Me!!!
EricS 91gt
Ok so here is my problem, I put headers, plugs and wires along with a h-pipe on my 91gt and with no pipes and it drove fine with all power... so here is where the problem starts, I got a guy to weld side pipes on it. I got the car back drove it home and floored it and it had no power. I pulled all the plugs rechecked all plug wires and still nothing. I replaced the tps, aic, act sensor, the ecm, maf, and the fuel filter.Took off the upper and lower intake cleaned them both and still nothing. The car is stock besides the fender mount and others I mentioned. My brother and I are both stumped. Btw its an auto. What stumps me is the only defining thing is the side pipes. Thanks in advance.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30-$36.
something tells me going from your closed system with a h pipe to side pipes got rid of all your back pressure and you now have no power
Sent from my iPhone using my fingers
Reactions: 1 user
Automatic with straight pipes? That's why.
No cats and no mufflers right? What you did was shift your power curve up eliminating a lot of low end torque. Reconnect your exhaust to your muffler and you should get your power back as you gain low end torque.
Had a buddy run his stock 89GT to a 14.7....then he put straight pipes on the car with dumps...ran a 15.5 later on. Only change was ditching the cats/mufflers
Ok so I borrowed a obd scanner and it couldn't read because it couldn't control idle rpms or something like that. So now gonna check that. As far as the back pressure issue, I drove the car with only headers and the h pipe and the car ran fine. It didn't start til after the side pipes were put on.
on a 91? use a paperclip. scanners are a waste of money on that year mustang.
Blast from the past.... my first Mustang was a black 67 that I blew up the 289 and swapped a 428 into. Had the thrush sidepipes and all.. lol Looked like this one. those stupid sidepipes hit every dam bump on the rode. But they sure helped to melt the snow in the winter...
Reactions: 1 user
