Help needed on check engine light codes
ThePope
25
Huntington, NY
For the past week I been getting check engine codes. P0420, P0430 and P1000 I did some research and found out what they are and what not. My car currently has a BBK off road H Pipe and flowmaster catback. I also purchased a diablosport predator. I have the car tuned to my likings with the rear o2s shut off. Is there something I can do so these codes don't keep comming on? I tryed looking here and on sn95forums but I wasn't able to find anything. If anyone can help, I thank you.
P0420 and P0430 is catalyst system efficiency codes. I would think that if you have the rear O2's shut off it would not set these codes. Does your diablo let you turn off the catalyst monitor?
P1000 is the monitors have not set yet however they won't set untill the other 2 are cleared and do not come back.
I hooked up the diablo again and I check the setting. I think I had the rear still on for some reason but I thought I shut them off. So I went through all the settings and made sure everthing was right. So tomorrow when I go to work, ill see what happens.
