Help needed with head gaskets
I'm installing new head gaskets. These are Ford graphite #F2TE-6051-CA gaskets. In the front these gaskets cover over two coolant passages from the block to the head. Should I cut the gaskets to match the block and heads or install them as is?
I came across the same thing but when I asked a friend that works at the local ford dealer, He said to just flip it over. I wasn't for certain that would work so I had him come over and do it so I could blame it on him if it doesn't work, But after endless dynos and track visits, Its been fine.
Jeremy
There seems to be a production issue with head gaskets, this might sound crazy but I drill the extra coolant holes into the head gaskets and have noticed a huge decrease of cylinder head temps!!
