Help needed with strutts
stangg01
129
I'm installing Eiback Pro strutts for my 2001 Mustang GT. I installed one side with the suplied spacers even though the original strutts didn't have any. I can't install any spacers for the other side. Any suggestions?
When I measure the space between the back of the flanges, the ones with the mounting holes, I need only one spacer to match the stock strut, not two as the other side needed. Should I instal it on the front side or the back side?
Thanks COrampant.
I think that your way will be easier than putting it in the front. Your way allows the bolt to hold the strut to the spindle while I play with the spacer. I think a wheel alignment will correct the strut being off center eather way, but I don't want to limit the caster.
