  • SN95 V6 Mustang Tech
help needed
  • Thread starter Thread starter 03edge
  • Start date Start date May 25, 2011
03edge
  • May 25, 2011
I have an 03 3.8 mustang with 123k miles and im having alot of problems right now (or at least i believe all of them are problems)
Ill start with the problem i hate the most and thats a pull to the left under braking... it varies in how bad it pulls depending on the conditions and it seems to pull harder in the cold... i have changed the right front caliper, ball joint, and bearing last yr. its stopped pulling after these changes but it now is doing it again.
The next problem i have is that it seems that the motor runs very flat at times. when i press the gas down the rpms barely pick up and the acceleration is almost non existent. i have just changed the plugs and wires 3 months ago. also during the winter i have problems starting the car... i turn the key and it will start and then immediately choke out and i have to hold the gas down enough to keep it running... while im holding the gas down i smell alot of exhaust and gas. i dont know if they can be related. no error codes at all and its not like this all the time but its been getting worse as time goes.
the final problem i have is that i have a very bad hard shift. its an auto trans and it does it often. this started about a yr after i bought it. im thinking about doing a tranny flush and using some internal cleaner. (dont know if this is a real problem or just how the car is)
02BLU3V6
20
Illinois
May 26, 2011
  • May 26, 2011
Try cleaning out your MAF sensor, that can cause your engine problems.
carstuff
florida
May 26, 2011
  • May 26, 2011
get new EGR valve and the switch for it as well.....had to do it for mine and the service engine soon light went away...power comes back immediately
03edge
  • May 26, 2011
i did that back in about February and it didnt change much 02blu
and car stuff i dont have a light on but could it still be a problem without it?
thanks keep em coming cause i want to get this all fixed. if anyone needs more info for ideas i can fill in whatever blanks u have
03edge
  • May 26, 2011
something to add to the engine issue. tonight the temp was pretty cool id say around 50s and the car ran alot better than it has been.
carstuff
florida
May 27, 2011
  • May 27, 2011
pull the codes on it....possible coil pack...possible egr valve but the thing sounds like its running rich if its hard start and you smell gas...hope the injectors arent dying...or gummed up from the crap gas our wonderful government regulators are shoving up our
carstuff
florida
May 27, 2011
  • May 27, 2011
Ill start with the problem i hate the most and thats a pull to the left under braking... it varies in how bad it pulls depending on the conditions and it seems to pull harder in the cold... i have changed the right front caliper, ball joint, and bearing last yr. its stopped pulling after these changes but it now is doing it again. maybe rotors need cut? or replaced?
carstuff
florida
May 27, 2011
  • May 27, 2011
have you changed your fuel filter yet?
03edge
  • May 27, 2011
there is no codes that i know of. and the starting problem is only during winter months when its cold. all summer it runs fine. i have thought about the injectors. what should i use to clean them.. ive been using lucas oil fuel treatments every now and then.
I turned the rotors when i changed the brakes last yr. i didnt see any problem with them. im gonna change the left side ball joint and see if that helps and grease the right side.
and no i havent changed the fuel filter yet.
thanks for the help carstuff... i hope some of this works
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
SN95 V6 Mustang Tech Sunday at 12:52 PM
