HELP! no power!
  • Thread starter Thread starter At1Maverick69
  • Start date Start date Nov 28, 2004
At1Maverick69
220
San Leandro, Cali
Nov 28, 2004
  • Nov 28, 2004
Hi! My 69 just died on me, well here's the whole story
a couple of weeks ago, I tried to start her up, and got nothing, I checked all my connections and everything was good, checked my battery, OK'd ground cable and + cable are new, alt is new.
then today, I tried again, battery is still charged good, so I thought I tried, after spraying some starting fluid, much to my amazement, she crank right up, had her idling for about 15 mins no prob! so I thought it would be good to drive her around. after a couple of blocks she just died when I came to a stop sign.
I am so dumbfounded here guys, somebody told me last week that it could a fusible link- where is this found? please help me out guys, thanks alot!!!!
MrBobMarley
460
Ft Myers, FL
Nov 28, 2004
  • Nov 28, 2004
Kinda sounds like a carb issue. Mine did that same thing once. Ran fine when idling. Put it in drive and it would sputter and die. Rebuilt it and all was well again. Maybe time for a rebuild?
At1Maverick69
220
San Leandro, Cali
Nov 28, 2004
  • Nov 28, 2004
Well, i dunno about that, cuz my carb is new too, and Im getting fuel into the engine, but when I try to crank it, there's nothing, no lights, no crank, no anything. if it was a fuel issue, I would at least crank, right?
2nd Mustang
2,488
Southern California
Nov 28, 2004
  • Nov 28, 2004
Does it only die when you come to a stop after you get it running? If you keep the rpms up, does it stay running? If it were electrical, I would think it wouldn't even crank or start at all. Your post sounds like two troubles, gas and fire.
At1Maverick69
220
San Leandro, Cali
Nov 28, 2004
  • Nov 28, 2004
well it all of a sudden just died, it stays running even when it's was just idling around 700-800. exactly, it didnt start nor did it crank at all. it was this way 2 weeks ago when I wanted to start it up, nothing, no lights even.
about gas, i doubt it's that, i get gas from the carb to the intake and if it was gas related, i would have lights and it would crank, right? or at elast hear the starter solenoid click. am I right??
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Nov 29, 2004
  • Nov 29, 2004
If your loosing all power, check both ends of both battery cables, and if you have those ****ty clamp on terminal ends, take them apart and clean them too. and clean all the ring connectors on the solinoid.
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 29, 2004
  • Nov 29, 2004
I had the exact same thing happen in my '65 (headlights work then don't work, cranks then nothing, idles then dies for no reason). Turned out, after hours of work with the voltmeter, that the old rubber connectors at the firewall weren't allowing current through consistently. When you plug them together, sometimes the bullet ends push through the back of the connector without you noticing resulting in poor or no continuity. Have a look, it'll only take a minute to rule it out.
blue66tang
1,092
Medford, OR
Nov 29, 2004
  • Nov 29, 2004
Same thing with mine. The connections at the fire wall sometimes come loose, check them out. I was just driving mine down the street at night, ladydyda, and then everything shut off. Scared the crap out of me. I couldnt see a thing.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
