Help, no Spark at all
crogers813
48
Trying to get the car to run and I still can't get any spark at all at any of the plug wires. What else do I try?
I have replaced:
Distro
Cap
Rotor
Plug wires
plugs
CCRM(Fan relay was blown)
Anyone know if this is accurate? Cause if it is, i'm only getting 3500 on both secondary resistances
cjones's Avatar
cjones cjones is offline
to test the coil;
get an Ohm meter and
check primary resistance between Pos and Neg terminals on the coil
resistance should be 0.3 - 1.0 ohms
check secondary resistance between Pos term and coil wire terminal
resistance should be 8000 - 11500 ohms
repeat secondary resistance test between Neg terminal and coil wire terminal
check resistance to each terminal and gound(coil case)
resistance should be infinite
CJones is a smart cookie.
The specs should be in your repair manual.
You can also put a test light across the coil's electrical connector. If the test light flashes while cranking but the coil does not have a spark output, that suggests a bad coil.
Good luck.
Good luck.
Curious , if the test light doesn't flash would that indicate a bad stator (PIP) and/or TFI module?
Assuming you have accessory 12V to the coil, it could be either. You'd go back to the TFI and test the output (to check the wiring inbetween) and then (if needed) test the other TFI values and the value at the SPOUT connector.
This is what I get, so I'm assuming the coil is bad.
Pri: .5 Sec: 3084
Below are the Specs. If I am right and it is bad, what kind should I replace it with?
Thanks
Brand MSD Ignition
Manufacturer's Part Number 5527
Part Type Ignition Coils
Product Line MSD Street Fire Coils
Summit Racing Part Number MSD-5527
Coil Wire Attachment Male/HEI
Coil Style E-core
Primary Resistance 0.440 ohms
Coil Internal Construction Epoxy
Coil Color Red
Maximum Voltage 48,000 V
Turns Ratio 85:1
Secondary Resistance 5.5K ohms
Inductance 7.0 mH
Peak Current 300 mA
Spark Duration 250 uS
Mounting Bracket Included No
Coil Wire Included No
Ballast Resistor Included No
Coil Shape Square
okay, so replaced the coil. Still no spark at all. so now the list of what I've replaced again:
COIL
Distro
Cap
Rotor
Plug wires
plugs
So what's next?
Did you do this test?
Check PIP (stator) and TFI module. I suspect PIP even though you indicate that the distributor was changed.
Just pulled the distro out, and along with it came the oil pump shaft, the stupid little retainer must have broke. Any chance that the shaft being stuck in the end of the distro would cause the PIP not to function?
I doubt that the oil pick up shaft would keep it from firing. it does sound like the pip though. its amazing what all it does control in there. i believe that it also controls the injector pulses as well or even letting the injectors pulse. i had a similar problem a long time ago which turned out to be that. but mine was intermittent with a new dizzy
I got a new MSD-ProBillet to try instead of the reman. stock one I got. I"m hoping it will work this time. If not, I'm running out of things to replace. Hope to install it tomorrow.
I hope that you haven't purchased that many parts to rule out faulty hardware that way. it sucks that its always a pain to find and i wish you the best and hope that fixes your issue.
okay, so finally got enough time to work on the car. replaced the reman. stock distro with the msd, and now I have spark at the number 1. It still doesn't start, but at least it's progress. I'm pretty sure now it's just a timing issue. Report back soon.
