Help! No Start!
  • Thread starter Thread starter ImportSlayer347
  • Start date Start date Oct 13, 2008
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
I made a huge mistake the other day. I was clamping on a new hose to the newly installed heater core (HUGE PAIN to install by the way). I clamped down on the hose and somehow got the injector hot wire caught in the clamp and crushed it. I did not notice and tried to start the car. The clamp got cherry red immediately and the car wouldn't start. I removed the clamp to get the crushed wire out and repaired the wire. Now the car will not start at all. I have no spark coming from the coil and I swapped coils with no luck. I cannot hear the fuel pump priming either. I checked all the fuses too. I tested the voltage on the hot injector wire and got a reading of 3.47 vdc. What have I done? I am so ashamed of myself.
amnit:
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
I also just tested the ECM at pins 37 and 57 (the VPWR pins) with the ignition on. They both also have that low voltage. So the ECM is ok. Is there any suggestions from the electrical guys out there?
Saleen0679
876
24
49
Yakima, WA
Oct 13, 2008
  • Oct 13, 2008
Checked your fusible links? Especially the 20 gauge blue one.
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
That is where I was heading next. Where is this infamous blue link? It is 20 gauge right?
Saleen0679
876
24
49
Yakima, WA
Oct 13, 2008
  • Oct 13, 2008
It's in with the mess of other links at the starter relay. It's kind of off by itself but hidden behind the other mess.
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
I can't find it. Crap!!
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
I looked underneath again and there is no other wires next to the starter solenoid exceprt the ones that attach. I found one blue fuselink coming out of the fender on the passenger side. Could that be the one?
Saleen0679
876
24
49
Yakima, WA
Oct 13, 2008
  • Oct 13, 2008
Not sure if your wiring layout is the same, but if you follow the wire loom that goes over the strut tower and down under the starter relay you should see the blue link coming out of the loom and curving back up to the relay. If yours has fried you may be looking for stubs of wire.
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
  • Oct 13, 2008
Is there another fuse block somewhere other than the one under the dash driver side?
Saleen0679
876
24
49
Yakima, WA
Oct 13, 2008
#10
  • Oct 13, 2008
  • #10
Not on a 93 if that's what you're working on.
The blue link on the passenger side is connected to the heaters on the O2 sensors.
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
#11
  • Oct 13, 2008
  • #11
yeah it is a 93. it was pretty much put together by hand though. i am so frustrated. i cannot find that link.
ImportSlayer347
173
Sarasota, FL
Oct 13, 2008
#12
  • Oct 13, 2008
  • #12
I found it! But it seems to be ok. It was green not blue, thats why I was thrown. It is the one right from the positive side of the starter relay.
What now?
Saleen0679
876
24
49
Yakima, WA
Oct 14, 2008
#13
  • Oct 14, 2008
  • #13
Well, unless you have more than one green link you have the wrong one. There's a green one on there too. A quick looks shows the stock setup should have a 14g green link, a yellow wire with three black 16g black links, a 18g brown link, and a 20g blue link. If the green link has a 18g brown link connected to it then that one goes to the alternator. That's not saying someone could have change a link at some time.
ImportSlayer347
173
Sarasota, FL
Oct 15, 2008
#14
  • Oct 15, 2008
  • #14
I found the blue one. It was a little discolored. I went to give it a little tug and it snapped off! I replaced it and vroom vroom the car fired right up.
Much thanks. You are the man!
Saleen0679
876
24
49
Yakima, WA
Oct 15, 2008
#15
  • Oct 15, 2008
  • #15
When you said the clamp got red hot I suspected the link was toast. It was probably more brown or black than blue. Glad to hear the circuit protection worked and no permanent damage was done.
  • dan50
  • Jul 18, 2026
dan50
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
