help on valve covers
  • Thread starter Thread starter 93killerbee
  • Start date Start date Apr 5, 2004
9
93killerbee
44
ohio
Apr 5, 2004
  • Apr 5, 2004
question about valve cover gaskets, can i reuse the stock rubber ones. if not are the qork ones that felpro make any good,
mike keirstead
1,121
ROLLING A JOINT
Apr 5, 2004
  • Apr 5, 2004
I always stick with the rubber type. The cork tend to tear apart. My Ford gaskets are great. Used them 10-12 times.
9
93killerbee
44
ohio
Apr 5, 2004
  • Apr 5, 2004
so that means i can reuse the rubber ones
mike keirstead
1,121
ROLLING A JOINT
Apr 5, 2004
  • Apr 5, 2004
If they are in good shape and did not leak.
9
93killerbee
44
ohio
Apr 5, 2004
  • Apr 5, 2004
thanks for the info and roll on haha
V
v8only
2,378
22
49
Apr 5, 2004
  • Apr 5, 2004
FYI, I had a hell of a time with the rubber ones and with the cork ones, they kept squeezing out on me and leaking.
The perfect solution came from frpp. They sell metal valve cover gaskets, that have a little bit of rubber on the ends. They in fact come on all motorsport packages, however, they sell them seperately. They are pretty much re useable indefinately, and are fool proof against leaking, and don't cost too much. that's the only way for me.
P
PRO50SC
1,012
Olney, Maryland
Apr 5, 2004
  • Apr 5, 2004
I believe those are the one he is asking about. Those are the ones that come factory on the car.
V
v8only
2,378
22
49
Apr 6, 2004
  • Apr 6, 2004
You're probably right, being that his car is a 93. FYI, they're 99% steel, 1% rubber, so when he said stock rubber ones, that led me to believe he didn't have those. I'm pretty sure only the later foxes had em too, maybe 90-93?? As my 86's don't have them.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
