help ordering pistons(compression)
  • Thread starter Thread starter blue87lx
  • Start date Start date Dec 18, 2005
blue87lx
175
  • Dec 18, 2005
im trying to order new pistons from summit and under the specifications of the piston it doesnt say what compression they will give me. all they give me is a compression distance. can someone help me on figuring out what compression ratio they will give me
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Dec 19, 2005
  • Dec 19, 2005
blue87lx said:
I'm trying to order new pistons from Summit and under the specifications of the piston it doesnt say what compression they will give me. All they give me is a compression distance.
Can someone help me on figuring out what compression ratio they will give me?
Summit should be able to give you enough piston info to answer some of the question.
Compression height is from the center point of the pin bore to the top of the piston. This is only relevant (to you) as to the block and rod/crank combo the piston will fit.
Have you tried typing "compression ratio calculator" into Google's search engine ??
http://www.rbracing-rsr.com/compstaticcalc.html
You have to gather all the pertinent info to plug into the variables and it will give you a theoretical compression ratio.
Good Luck.
Rick 91GT
Mustang Master
95
99
PA
Dec 19, 2005
  • Dec 19, 2005
If this is a stock 302 you have a 5.09" rod, 3" stroke and the CH of the piston is 1.600"
What is the cc of the valve relief, what head are you running?
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
