  • SN95 4.6L Mustang Tech
help out a newbie
  • Thread starter Thread starter alexm
  • Start date Start date Nov 5, 2006
A
alexm
  • Nov 5, 2006
i have a 2001 gt, 62k miles on it with vortex exhaust and a k&n cold air intake. i have a few questions and i was hoping some folks with the know-how on here could help me out, here it goes:
-how many quarts of oil do i put in when changing the oil?
-what oil do you recommend for overall performance and life and how often should it be changed?
-where are the lift points located at?
any help would be appreciated.
P
Pennywise2
Banned
May 16, 2006
1,379
  • Nov 5, 2006
Welcome to Stangnet.
I belive your car takes five quarts but,you can always
check your dipstick after you put in the motor oil.
I only use Mobil 1 in my car it's great stuff and can be
found at your local Walmart.
Different oil filters filter differently so,I would be choicey
on what oil filter you put on your car.I use Motorcraft oil
filters because they have the drain back valve witch is good.
Also if you want to prolong the life of your engine you should
change your motor oil frequently.I change mine every three months
or three thousand miles whatever comes first that is four oil changes
a year no big deal.
the98stang
2,408
Clovis, CA
Nov 5, 2006
  • Nov 5, 2006
1. Check your owners manual or buy a Haynes book.
2. 5w-30 or 10w-30 oil is fine. Use synthetic if money permits. Use a motorcraft filter or Mobil 1 filter.
3. I don't know wtf you mean by "lift points"
the98stang
2,408
Clovis, CA
Nov 5, 2006
  • Nov 5, 2006
a year no big deal.
aparently synthetics can go 5k miles easy, but mobil 1 synthetic is dirt cheap at walmart, so I change every 3k as well. I vote for motorcraft filters as well. Around $2 at walmart
sgarlic
3,085
Nov 6, 2006
  • Nov 6, 2006
For oil, fill it til its between low and max on the fillline.. forget about how much oil the manual says.. earlier ones say 5 qts, mine says 6.. same engine though.
Here's a diagram of the lift points:
12amracer
366
Birmingham, Al
Nov 7, 2006
  • Nov 7, 2006
If you need the lift points to jack the car up for an oil change, i suggest getting a set of Rhino Ramps. It's quicker, and actually will get the car higher up in the air. Walmart probably has the best price.
http://www.cadillacfaq.com/faq/answers/stealthv/cones/2.jpg
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Nov 7, 2006
  • Nov 7, 2006
+1. Rhino ramps make it a whole lot easier to do. Got mine from Auto zone for like $30-40.
Oil, I use Amsoil, not the cheapest stuff but works real well for me along with a motorcraaft filter.
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 7, 2006
  • Nov 7, 2006
it's 6 quarts......
kramer03gt
90
madison, WI
Nov 7, 2006
  • Nov 7, 2006
Another one for AMS oil here i use there filter as well. seems to be ok.. might try the royal purple route next to see if there is a huge difference or not..
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
S302 Saleen supercharger help
  • sschoup
  • Nov 19, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Nov 19, 2025
sschoup
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
