Hey Guys,
Car is an 87 5.0L GT. Stock motor other than exhaust.
190kms on it, ran great up till now.
A description of what the car is doing would be missing badly from what sounds like 1 cylinder only ( continuous miss under throttle, rhythmic, not scattered).
Pulled codes, just got the usual emissions codes (thermactor bypassed). Did the cylinder balance test, passed with no codes.
Car does not miss at idle, or if it does, it's very infrequent. I can very lightly cruise just above idle with no missing. As soon as i get on the throttle any amount, it misses.
No backfiring or anything, just shudders and bucks. At WOT the miss is constant. Car still pulls decently hard, but with about 3/4 the power of normal. Car doesn't run any hotter than normal.
Problem came on suddenly.
What i've done, pulled all the plugs (pics below), checked wires, new cap and rotor, new fuel filter. Couple bottles of injector cleaner with 1/4 tank, no difference.
Left to right = front to back
Drivers side #6 looks a little lean.
Pass side, #4 is clean because the plug was changed 3 days ago.
Right now I'm suspecting a fuel delivery issue. I changed the filter, fuel has pressure at the rail, but not sure exactly how much.
I'm suspecting a clogged injector since none of the plugs are fouling i believe it is a fuel issue.
I'm leaning to a partially plugged injector since the miss seems to be in one cylinder only. (#6 is my guess)
Any insight is very much appreciated.
Mike
Mike
