  • 1994 - 1995 Specific Tech
HELP PLEASE 94 GT
  • Thread starter Thread starter vladasap
  • Start date Start date May 6, 2006
vladasap
294
nyc, ny
May 6, 2006
  • May 6, 2006
please give me suggestions as to what i should do ... here's the scenario--->
I bought a 1994 GT where after a minute of driving the check engine lights up. I ran the codes and it read it was code 332. Now, thats EGR valve related but its been giving me such weird symptoms i dunno what to do. Sometimes the rpm's drop really low at idle and then jump back up and finally stop at the normal. It would make a knockin sound for a lil while and then stop, then it would backfire at low rpm's (1.2-2) occasionally, it doesnt pull as hard as it used to and finally if i gas it up hard it would "shoot" out dark smoke (smog) out of the exhausts. PLEASEEE give me suggestions as to whether to clean in or get a new one or.... what is my problem, what do i do ?!?!?!
*if u had such an experience - what happened?
THANKS
btw - everything is stock and im very short on money
mootang
907
texas
May 6, 2006
  • May 6, 2006
what modifications does it have?
vladasap
294
nyc, ny
May 6, 2006
  • May 6, 2006
it is completely stock, no mods what so ever i got it from some 50 year old fossil who drove it once every two weeks so...
DFG 5OH
1,341
Louisville, KY
May 6, 2006
  • May 6, 2006
well the EGR being messed up can cause some really weird problems. Look it over, check for cracks, leaks...
BlackVert
5,589
9
98
Bethesda, MD
May 6, 2006
  • May 6, 2006
very dark smoke coming out of the exhaust usually means too rich a mixture, probably because the mass air flow (maf) sensor is dirty.
clean the maf sensor.
you could probably use a tune up too: new fuel filter, distributor cap and rotor, and check the spark plugs and wires.
i'm almost 50 years old myself ... and i'm no fossil
HISSIN50
34
129
May 6, 2006
  • May 6, 2006
If you remove the vac line from the EGR valve, does the idle increase? It sounds like your EGR is leaking. You can remove it and clean out the passages - a piece of carbon can hold the valve open (from seating).
Good luck.
bonestock94
61
NY
May 6, 2006
  • May 6, 2006
Im having similar problems, excepting for the knocking part...
WhiteCobra95
641
180
74
May 7, 2006
  • May 7, 2006
I agree. It sounds like your EGR valve is going bad. The <'96 use OBD1, which is more difficult to nail down the exact failure type, but chances are your valve is either bad or needs a good cleaning. I don't know about hte FOX3 cars, but SN95 5.0's have an EGR valve position feadback monitor. If the control solenoid is being comanded to drive the valve to a certain position and the position feadback is showing something different (within a certain tolerance window), the system will set an SES light. These Ford systems have really bad idle speed control and if you have a leaking valve, the system will hunt to try and hold the engine speed. I don't know why your engine would knock, unless it's when your speed drops too low (like 400rp). If that's the case, then the controller will open up the IAC and the load will increase significnatly to try and raise the speed. At low engine speeds/ high loads, the knock threshold is faiirly low.
I blocked off my EGR valve with a custom made solid gasket. (An engine shouldn't be fead it's own S***.) My idle hunts around every once in a while I think the system is expecting a reaction from the EGR system, but I don't have the black smoke or missing you described.
Good luck, Whitecobra 95
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
