Help Please Pump Question
None that we can use the pump from. The SVT Focus pump is a common swap on the 4.6 cars, but their pumps are variable speed. Ours with the return style system run at a constant speed.
My buddy put on of them 255 on his pretty much stock 92 5.0 will it hurt anything?
Nope. The only thing i think might happen he might waste a little more fuel for the added pressure but if he has a adjustable fuel pressure regulater he can turn it down. I may be wrong on that but Im sure he isnt hurting anything.
Guero is right about the bigger pump.
For an OEM application, would something like a Lightning use a 255 that might fit? Seems like 97-02's use GSS342's.
How about a Terminator pump?
I just looked that up. I dont know if the tanks and pump install kits differ a lot for trucks...... Double check the ratings for the application if you can somehow make that work.
Otherwise, I'd see if you can just special order the Walbro pump you need.
Good luck bud.
